Application for HCS12
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Jul 6 19:30:54 UTC 2004
HDL-MikeFriedrichs wrote:
> Thanks for your encouragement.  I will port RTEMS over to the HCS12.
Great!!  Please work from the CVS source.  Also there is a CPU
supplement document which attempts to capture the port specific
information someone might want to know.  There is a standard
format for it and a template is in docs/supplements/template.
If there is a good simulator that works with gdb, then
do a simulator BSP first and focus on getting hello world
up.  That will even test the context switch.  You can
run a lot of the tests without a clock tick.  If the
simulator has a simulatod clock tick interrupt source,
then you can do the entire port without every waiting
for code to download.
--joel
> MikeF
> At 09:38 07/06/2004, Joel Sherrill <joel at OARcorp.com> wrote:
>> Sorry for not getting to you personally.  I have been on a tight
>> deadline just before a holiday.
>>> Hello,
>>> I have been tasked with finding a RTOS for a Motorola HCS12, 16 bit
>>> micro-controller.
>>> Is the RTEMS a good fit for this device, or I am I expecting too much
>>> from this 16 bit micro-controller?
>> I don't think you are expecting too much.  Given a good gcc port and
>> a simulator, a port can be done fairly painlessly.  Most of the effort
>> is in .h code describing the processor -- stack grows up/down, has an
>> FPU, etc.  The only assembler code is usually the context switch and
>> interrupt processing.  And on some CPUs, this has even been done in
>> C.  The SuperH (SH) and TI C3x/C4x DSPs do the interrupt dispatching in
>> C.  The core of the MIPS interrupt vector selection is CPU model
>> dependent and usually in C.
>>> This device has 16 bit registers, 64 Mbyte of flash, 4Kbytes of ram,
>>> and paged memory expansion, running a 24Mhz bus.
>> The 16 bit part is not a problem.  There is a port to the Reneas
>> (Hitachi) H8 series.
>> RTEMS uses a stack per task and some memory itself for housekeeping.
>> 4K of RAM is light.  RAM usage is proportional to the number of RTEMS
>> objects created.  Flash usage is going to be proportional to the
>> number of services used.  Each port selects the minimal stack size.
>> You can run every non-networked RTEMS test in less than 256K of code
>> space.  Offhand, I would guess that the worst RAM usage in a test
>> is one of the timing tests which creates 100 tasks.
>> With external RAM, there should not be a problem.
>> --joel
>>> Thanks,
>>> MikeF
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel at OARcorp.com                 On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>    Support Available             (256) 722-9985
