Mr Angelo Fraietta, One more question...How to create a persistent File?
Angelo Fraietta
afraiett at bigpond.net.au
Wed Jul 14 22:56:50 UTC 2004
Joe OS wrote:
> HEllo Mr Angelo and thank you for for help...
> I used you source code, I compiled it and I runned it
> using a floppy disk with grub.
> I executeed the program, created file, etc but I cant
> see the file... :-(
First, are you using a DOS formatted Hard disk? Did you successfully
mount it in RTEMS?
When you created the file, did you create it as /dev/hda1/abc.txt
After performing the write, do a listing of the directory /dev/hda1
as there have been issue regarding flushing the file to the actual disk.
> Where is it supposed to be created the file whem I
> supply the abc.txt name?
It will be on the root of the hard drive
Everything works fine but
> when returning to linux I cant find the file in the
> floppy nor in the hd...
> Please, tell me, Can I browse the rtems file using
> linux cat command?
You should be able to.
> please, sorry about this questions but is beeing for
> me to understanding this subject...
> Many thanks for you time...
No problem
> Alex
> --- Angelo Fraietta <afraiett at bigpond.net.au> wrote:
>>Joe OS wrote:
>>>Hi,
>>>A sample source code would be appreciated...
>>There is a bit of a quirk in that the file does not
>>get flushed to the
>>disk immediately after writing. To get around this,
>>write a dummy file
>>after the one you want to keep.
>>Angelo Fraietta
>>PO Box 859
>>Hamilton NSW 2303
>>Home Page
>>http://www.users.bigpond.com/angelo_f/
>>There are those who seek knowledge for the sake of
>>knowledge - that is
>>CURIOSITY
>>There are those who seek knowledge to be known by
>>others - that is VANITY
>>There are those who seek knowledge in order to serve
>>- that is LOVE
>> Bernard of Clairvaux (1090 - 1153)
>>ATTACHMENT part 2 application/zip
> name=testfileio.zip
> __________________________________
> Do you Yahoo!?
> Yahoo! Mail Address AutoComplete - You start. We finish.
> http://promotions.yahoo.com/new_mail
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
