interrupt handling on task scheduling
Jay Monkman
jtm-list-rtems at smoothsmoothie.com
Mon Jul 19 18:08:47 UTC 2004
On Mon, Jul 19, 2004 at 07:11:51PM +0200, Francesco Poletti wrote:
> Hi Joel,
> thanks for the first answer...Sorry to bother you again...
> We discovered that for the arm boards the function
> _CPU_ISR_Disable(level);
> _CPU_ISR_Enable(level);
> Doesn't change the previous state of the interrupt instead the
I'm not sure what you mean here. _CPU_ISR_Disable() sets the I and F
bits in the CPSR, and _CPU_ISR_Enable() restores them.
> _CPU_ISR_Set_level(); When is invoked it enables all the interrupt.
I just looked at this macro, and it's wrong. It always clears the I
and F bits, enabling interrupts, regardless of the value for
new_level. The macro should be:
#define _CPU_ISR_Set_level( new_level ) \
int reg = 0; /* to avoid warning */ \
asm volatile ("MRS %0, cpsr \n" \
"BIC %0, %0, #0xc0 \n" \
"ORR %0, %0, %2 \n" \
"MSR cpsr_c, %0 \n" \
: "=r" (reg) \
: "0" (reg), "r" (new_level); \
And here's a patch:
Index: cpukit/score/cpu/arm/rtems/score/cpu.h
--- cpukit/score/cpu/arm/rtems/score/cpu.h (revision 77)
+++ cpukit/score/cpu/arm/rtems/score/cpu.h (working copy)
@@ -572,7 +572,7 @@
: "=r" (reg) \
- : "r" (reg), "0" (reg)); \
+ : "0" (reg), "r" (new_level); \
Name: not available
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20040719/0f83969a/attachment.bin>
