Executive shutdown
Angelo Fraietta afraiett at bigpond.net.au
Fri Jul 2 08:39:24 UTC 2004
Stevens Brian wrote:
>RTEMS version 4.6
>Target PC386
>I have written a device driver to use the rtc to generate timer interrupts
>independent of the clock used to drive rtems. I have set  the additional
>timer to produce interupts at 122micro second intervals, these are then
>counted and when the required time interval has elapsed a POSIX signal is
>sent to a thread.
>If I set the signal to be sent every  2 miliseconds the system eventually
>crashes with an executive shutdown. However, if set to 20ms it works fine.
After how long does it crash? Do you get a message saying that it shust down
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
