Problem with ATA driver on pc386
Eugene Denisov dea at sendmail.ru
Fri Jul 2 10:44:47 UTC 2004
Hello Angelo,
Friday, July 2, 2004, 9:48:59 AM, you wrote:
AF> Eugene Denisov wrote:
>>Hello all.
>>I trying to use ATA driver in RTEMS 4.6.0pre5 on pc386 target, this is the
>>driver table I used to:
>>#define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
>>#ifdef CONFIGURE_INIT
>>rtems_driver_address_table Device_drivers[] =
>>        CONSOLE_DRIVER_TABLE_ENTRY
>>        ,CLOCK_DRIVER_TABLE_ENTRY
>>        ,IDE_CONTROLLER_DRIVER_TABLE_ENTRY
>>#if 1
>>        ,ATA_DRIVER_TABLE_ENTRY
>>#endif
>>Unfortunately system hungs up when I enabling ATA driver.
>>Does anyone succesfully use ATA driver for this RTEMS build?
AF> Did you get this sorted. I am having the same problem here, but only
AF> with the new PC104 module that I have. 4.6.0pre5 works with the IDE on
AF> my DIMMPC but not the PC104. Same as you, if I enable the ATA, the
AF> system hangs.
Yes  I  did,  however  I think my problem was not similar to yours. I
found the cause in multiple file systems on my hdd and GRUB installed in MBR.
Best regards,
 Eugene                            mailto:dea at sendmail.ru
