Problem with ATA driver on pc386
Angelo Fraietta afraiett at bigpond.net.au
Sun Jul 4 04:35:21 UTC 2004
Greetings Eugene
>>>Unfortunately system hungs up when I enabling ATA driver.
>AF> Did you get this sorted. I am having the same problem here, but only
>AF> with the new PC104 module that I have. 4.6.0pre5 works with the IDE on
>AF> my DIMMPC but not the PC104. Same as you, if I enable the ATA, the
>AF> system hangs.
>Yes  I  did,  however  I think my problem was not similar to yours. I
>found the cause in multiple file systems on my hdd and GRUB installed in MBR.
This is probably not as dissimilar as you suspect. This made me do some
more tests and have identified where the problem may lie.
What I did not mention is that my PC104 system does not have any drives
plugged into the primary IDE -- the compact flash is the secondary master.
If on my DIMMPC, I disable the onboard IDE (i.e. no hard drive), the
system hangs at the same place - ATA_DRIVER_TABLE_ENTRY
What I suspect is happening is that the absence of a drive in the
Primary IDE cause the initialisation to hang. I don't have a drive that
I can plug into the primary IDE of the PC104 to prove this. I'll try and
get my hands on one to substantiate my theory.
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
