Help: Creating a file...
Eugeny S. Mints emints at ru.mvista.com
Fri Jul 9 10:38:17 UTC 2004
Hi all,
Victor V. Vengerov wrote:
> Alex,
> Alex wrote:
>> Hi all,
>> I still cant create a file using rtems i386 686 bsp, linux :-(
>> Does rtems has any default file system ?
> Yes, it is IMFS - "In-Memory File System". It is not persistent, of course.
>> The code works well but I cant see the file :-(
>> I want to do the folowing:
>> I try the rtems program using a floppy disk, and grup booting.
> No floppy disk driver available. Only ATA driver exists now.
I believe a floppy disk driver exists but not included into current
RTEMS source tree. Hopefully it might be found in contrib directory on
the RTEMS ftp site or elsewhere - please try to check mail list archive.
>> I want to create a file in that floppy disk when I execute the rtems
>> program, is this possible?
> You need to develop floppy driver to do that. :-(
>> Do I need any extra tool?
>> Any tips? advices? Source code?
>> Please see the source code i am using (from rtems samples):
>> The code work well, but where are the file?
> File created in IMFS, and disappeared when RTEMS application exitted.
> Victor
