Re^2: Mr Thomas, one more question please... [Initializing Partition Table (?)]
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Tue Jul 27 15:12:41 UTC 2004
Thomas Doerfler wrote:
> Joe,
> I should have mentioned: you might want to use the
> TFTP or FTP client instead. With these clients
> (available in RTEMS) you can either open and read or
> create and write files on a notwork file server. So
> maybe this is a solution for you.
TIll's site also has an NFS client for RTEMS.
http://www.slac.stanford.edu/~strauman/rtems/nfs/index.html
--joel
> wkr,
> Thomas.
>>Hi Mr Thomas, and thanks once more again,
>>So, I have a mandrake linux box using a 80GB had disk
>>which was limited to 40Gb due to mother noard
>>restrictions. I only have the madrake linux installed
>>in that computer, a mendocino celeron at 400MHz.
>>Does the hardisk must be FAT formated???
>>The hard disk I have is formated using linux
>>filesystem. I installed mandrake with the express
>>option and it created the linux needed partitions...
>>So when I try to mount it using fileio sample I get a
>>return value diferent from zero and the last error is
>>25 - file or directory doens exists... :-(
>>I dont have any FAT formated hard disk... :-(
>>Can I use a floppy instead? I am starting the rtems
>>program using a grub diskette which was formated using
>>fat system... Can I use it to be mounted?
>>How do I refere to the floppy when mounting and
>>initializing using the fileio samples? /dev/fd0?
>>Many thanks, once more again...
>>I ama student and I am trying to make some research
>>in the rtems but I need to create a file to store some
>>values for later use...
>>Joe
>>--- Thomas Doerfler <Thomas.Doerfler at imd-systems.de>
>>wrote:
>>>Hello,
>>>yes, I think the IDE and ATA driver should
>>>initialize on your system. So in the "fileio" menu,
>>>you should call "fileio_part_table_initialize" (menu
>>>letter 'p') and then "fileio_fsmount" (menu letter
>>>'f'). Then your first harddisk partition with FAT
>>>filesystem should be mounted to /mnt/hda.
>>>What messages do you get, when you call
>>>"fileio_mount"? What kind of harddisk do you use and
>>>how is it partitioned?
>>>wkr,
>>>Thomas.
>>>>Hello Mr Thomas and thank you for your help,
>>>>I have the following instruction in my rtems
>>>program
>>>>and I realize that the RTEMS_BSP_HAS_IDE_DRIVER is
>>>>defined!
>>>>rtems_driver_address_table Device_drivers[] =
>>>> CONSOLE_DRIVER_TABLE_ENTRY
>>>> ,CLOCK_DRIVER_TABLE_ENTRY
>>>>#ifdef RTEMS_BSP_HAS_IDE_DRIVER
>>>> ,IDE_CONTROLLER_DRIVER_TABLE_ENTRY
>>>> /* important: ATA driver must be after ide
>>>drivers
>>>> ,ATA_DRIVER_TABLE_ENTRY
>>>>#endif
>>>>But I cant see the hda anyway... :-(
>>>>That instruction is enough to load and initialize
>>>the
>>>>hardisk driver?
>>>>So, please, could you give a quick look at the
>>>>scaletton of my program... I cant solve this
>>>problem
>>>>alone... Did you saw anything suspicious? Do I
>>>have to
>>>>include any special parameter when I configure and
>>>>build the rtems to access hard drive?
>>>>Thank you Mr Thomas...
>>>>Joe
>>>>PS: My program is in one file only called hello.c
>>>and
>>>>i want to use POSIX api as much as possible...
>>>>#define CONFIGURE_INIT
>>>>#include <bsp.h> /* for device driver prototypes
>>>>#include <libchip/ata.h> /* for ata driver
>>>prototype
>>>>#include <libchip/ide_ctrl.h> /* for general ide
>>>>driver prototype */
>>>>#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>>>#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>>>#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>>>>#define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
>>>>#ifdef CONFIGURE_INIT
>>>drivers */
>>>>#endif
>>>>#include <rtems/bdbuf.h>
>>>>rtems_bdbuf_config rtems_bdbuf_configuration[] = {
>>>> {512,128,NULL}
>>>>int rtems_bdbuf_configuration_size =(
>>>>sizeof(rtems_bdbuf_configuration)
>>>> /sizeof(rtems_bdbuf_configuration[0]));
>>>>#endif
>>>>#include <unistd.h>
>>>>#include <rtems/error.h>
>>>>#include <dosfs.h>
>>>>#include <ctype.h>
>>>>#include <rtems/ide_part_table.h>
>>>>#include <rtems/libcsupport.h>
>>>>#include "fsmount.h"
>>>>#include <rtems.h>
>>>>#include <stdlib.h>
>>>>#include <stdio.h>
>>>>#include <string.h>
>>>>#include <errno.h>
>>>>#include <semaphore.h>
>>>>#include <pthread.h>
>>>>#include <fcntl.h>
>>>>#include <time.h>
>>>>#include <rtems/posix/timer.h>
>>>>#define print_time(_s1, _tb, _s2) \
>>>> do { \
>>>> printf( "%s%02d:%02d:%02d %02d/%02d/%04d%s",
>>>> _s1, (_tb)->hour, (_tb)->minute,
>>>(_tb)->second,
>>>> (_tb)->month, (_tb)->day, (_tb)->year, _s2
>>>> fflush(stdout); \
>>>> } while ( 0 )
>>>> * Macro to print an task name that is composed
>>>of
>>>>ASCII characters.
>>>>#define put_name( _name, _crlf ) \
>>>> do { \
>>>> rtems_unsigned32 c0, c1, c2, c3; \
>>>> c0 = ((_name) >> 24) & 0xff; \
>>>> c1 = ((_name) >> 16) & 0xff; \
>>>> c2 = ((_name) >> 8) & 0xff; \
>>>> c3 = (_name) & 0xff; \
>>>> putchar( (char)c0 ); \
>>>> if ( c1 ) putchar( (char)c1 ); \
>>>> if ( c2 ) putchar( (char)c2 ); \
>>>> if ( c3 ) putchar( (char)c3 ); \
>>>> if ( (_crlf) ) \
>>>> putchar( '\n' ); \
>>>> } while (0)
>>>> * static inline routine to make obtaining ticks
>>>per
>>>>second easier.
>>>>static inline rtems_unsigned32
>>>get_ticks_per_second(
>>>>void )
>>>> rtems_interval ticks_per_second;
>>>> (void) rtems_clock_get(
>>>>RTEMS_CLOCK_GET_TICKS_PER_SECOND,
>>>&ticks_per_second );
>>>> return ticks_per_second;
>>>> * This allows us to view the "Test_task"
>>>>instantiations as a set
>>>> * of numbered tasks by eliminating the number of
>>>>application
>>>> * tasks created.
>>>> * In reality, this is too complex for the
>>>purposes
>>>>of this
>>>> * example. It would have been easier to pass a
>>>task
>>>>argument. :)
>>>> * But it shows how rtems_id's can sometimes be
>>>used.
>>>>#define task_number( tid ) \
>>>> ( rtems_get_index( tid ) - \
>>rtems_configuration_get_rtems_api_configuration()->number_of_initialization_tasks
>>>>/* end of include file */
>>=== message truncated ===
>>__________________________________
>>Do you Yahoo!?
>>Yahoo! Mail - 50x more storage than other providers!
>>http://promotions.yahoo.com/new_mail
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler Herbststrasse 8
> D-82178 Puchheim Germany
> email: Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_keys.htm
joel at OARcorp.com On-Line Applications Research
