TCP fragmentation issue
Chris Johns cjohns at cybertec.com.au
Mon Jun 14 23:47:39 UTC 2004
Ian Caddy wrote:
> I thought I would look into 4.6.1 to see if it was still handled the
> same way and it appears to be, although I can't find the param.h file,
> in fact I can't find a definition anywhere in the tree for MSIZE! (I
> even greped the whole tree *.*)
It is in newlib:
  newlib/newlib/libc/sys/rtems/sys/param.h
> I have two choices.  The first is to modify sosend to link in the second
> mbuf to send the whole frame, or the other option is manually modify the
> minimum cluster size to it matches up with the mbuf size with no gap.  I
>  will let you all know how I go.
What happens if a router fragments the packets due to varying MTU sizes
in the path ?
  Chris Johns
