rpms again
D. Peter Siddons siddons at bnl.gov
Fri Jun 18 14:19:02 UTC 2004
Hi Sergey,
   Thanks very much. That solved the problem. Options '--nosignature
--nodigest' suppress the error message. It still leaves the question of
why the signatures are bad, and if one has to work to suppress their
use, what function do they serve?
Anyhow, the binutils install now fails because of an unmet dependancy:
# rpm --nosignature --nodigest -i
rtems-4.6-m68k-rtems-binutils-2.13.2.1-2.i686.rpm
error: Failed dependencies:
        rtems-4.6-rtems-base-binutils is needed by
I can't find a 'rtems-4.6-rtems-base-binutils' package anywhere. Also,
this package is not indicated as needed by the download-helper web
page.  Is it me, or is something wrong?
Pete.
Sergey Ablalimov wrote:
>I'm not an RedHat expert, but I suspect that
>rpm --nosignature -i rtems-4.6-m68k-rtems-binutils-2.13.2.1-2.i686.rpm
>must work. You also can try --nodigest and --nomd5 options. See
>rpm --help
>for details.
>Thursday, June 17, 2004, 2:42:14 AM, you wrote:
>>Sorry all, but I'm still unable to open the rpm tool packages from the
>>website. I did the following:
>>I downloaded the package files plus the gpg-pubkey-EAC29B6F file.
>>I did:
>># rpm --import gpg-pubkey-EAC29B6F
>># rpm --checksig rtems-4.6-m68k-rtems-binutils-2.13.2.1-2.i686.rpm
>>and got:
>>rtems-4.6-m68k-rtems-binutils-2.13.2.1-2.i686.rpm: MD5 GPG NOT OK
>>then:
>># rpm -i rtems-4.6-m68k-rtems-binutils-2.13.2.1-2.i686.rpm
>>error: rtems-4.6-m68k-rtems-binutils-2.13.2.1-2.i686.rpm: V3 DSA
>>signature: BAD, key ID eac29b6f
>>error: rtems-4.6-m68k-rtems-binutils-2.13.2.1-2.i686.rpm cannot be installed
>>What am I doing wrong? This is on Redhat EL. I'm new to redhat. It's
>>very tempting to go back to Debian!
>>Pete.
