true rtems posix program??
Joe OS
joe_os2001 at yahoo.com
Wed Jun 30 14:01:49 UTC 2004
Hi,
I am a beginner concerning rtems. I already made some
simple programs
and they workek.
In these programs I used configuration information
like
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MICROSECONDS_PER_TICK 1000
#define CONFIGURE_TICKS_PER_TIMESLICE 1
#define CONFIGURE_MAXIMUM_TASKS 1
#define CONFIGURE_MICROSECONDS_INIT
#define CONFIGURE_INIT
#include <confdefs.h>
So everything worked fine.
Now, I want to write rtems programs with the
portability in mind,
like, use the main() function and posic api. So I
wrote one simple
program using the main() instruction, instead of the
rtems macro
representing the main. I
#include <sys/time.h>
int main()
puts( "\n\n*** POSIX PROGRAM ***" );
return 0;
I used the make file of the rtmes program version to
build this c posix
like program and everuthing worked fine. Remember that
I didnt define
any symbols and didnt include the confdefs.h either!!
But it worked!
Now I want to launch one extra thread and the problem
arises:
#include <pthread.h>
void task2()
int counter=0;
int i;
for(i=0;i<100000;i++)
counter++;
if((counter % 10000) == 0)
puts( " P " );
int main()
pthread_t count;
int taskparameter = 0;
//Start task 2
int task_ret;
task_ret = pthread_create(&count, NULL, (void *)
task2, (void *)
&taskparameter);
if (task_ret)
perror("error creating task2");
return 0;
pthread_join(count,NULL);
return 0;
Every time the program is executed, the
pthread_create() function
always fails! Once more again, I didnt define any
symbols nor
confdefs.h, because if I define for example
many errors appear during execution of the original
make file
My question is:
When using the c posix fashion, using the pure main()
function,
is it needed to define the symbols and use confdefs,
or there is
other way to compile a program
I searched in the rtems samples and didnt find any
programs using
the main() function, so any c posix fashion sample
program and make
file would be appreciated
Any comments?
Thanks to everybody,
Joe
__________________________________
Do you Yahoo!?
Yahoo! Mail Address AutoComplete - You start. We finish.
http://promotions.yahoo.com/new_mail
