Disparity in Semaphores' performance
sashti srinivasan
svasn_rtems at yahoo.com
Mon Mar 1 04:43:29 UTC 2004
Hello,
I am writing a performance test-bench for posix
compliant operating systems. In order to validate my
test-suite, I compared the results with tmtests
distributed with rtems.
Here is a small set of results:
tmtests | my posix tests
rtems_semaphore_create(9) | sem_init (11 usec)
rtems_semaphore_delete(10) | sem_destroy(22
usec)
Please guide me whether 12 microseconds
difference between destroying a rtems-semaphore and a
posix-semaphore is theoretically possible.
In the tmtests, I find calls to functions
Read_timer, Timer_initialize. I could not find them
in any document. Probably they are not
rtems-directives. I hope Read_timer gives time in
microseconds. Please correct me if I am wrong.
In tsim, I find that the function gettimeofday()
returns a same value whenever it is called. But on
posix bsp, it works. Any special configuration is
required to get this working on tsim?
Regards
Srinivasan
__________________________________
Do you Yahoo!?
Get better spam protection with Yahoo! Mail.
http://antispam.yahoo.com/tools
