gettimeofday(): Help please
Fri Mar 5 12:05:00 UTC 2004
sashti srinivasan wrote:
>Hello,
>     With best support from the list, I could have my
>pc386 booting with grub-rtems.  In my applications, I
>have posted my problems to the list.  I infer that,
>the error "raw handler connexion failed" is only
>because of the usage of functions Initialize_timer(),
>Read_timer().  If I do without this by invoking
>gettimeofday(), I could run the application, but
>results are not of any use.  Because, it appears,
>gettimeofday() always returns a constant value.  It
>was like this in sparc-rtems(TSIM) also. Please help
>me in getting atleast one of the problems solved.
I don't know why the pc386 BSP is doing that. But if the sparc is
returning a constant value, then you most likely did not configure the
clock driver.
Are you defining both these before including confdefs.h?
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
Is your test case simple enough to post?
--joel
>With Regards
>Srinivasan
>__________________________________
>Do you Yahoo!?
>Yahoo! Search - Find what you’re looking for faster
>http://search.yahoo.com
