[Fwd: libcpu/powerpc Port to MPC5XX]
Ralf Corsepius corsepiu at faw.uni-ulm.de
Fri Mar 5 18:12:22 UTC 2004
On Tue, 2004-02-24 at 17:26, Joel Sherrill wrote:
> Attached is Wilfried Busalski's work to support the
> MPC5xx.  .RAR is not something I normally deal with
> and I do nopt know how to decode it.
> I was hoping that others working on these
> CPU models coulld integrate this effort with theirs
> and prepare one submission.
I have merged Wilfried's work into my local rtems-4.7 source tree, but
have encountered problems with it:
1. Wilfried's code is incomplete.
* The corresponding cpuIdent* support code is missing (I'd expect this
to be trivial for somebody being familiar with the mpc5xx's)
* There is no BSP (The only possibility to compile this code is the bare
BSP).
2. It is not clear to me which mpc5xx cpus this code is supposed to
support nor which gcc target flags this code expects (powerpc-gcc has
plenty of -mcpu flags)
3. How is this code supposed to interact with the code in
libcpu/powerpc/mpc505 - Is it to replacement that code? Is it an
alternative?
All in all, I don't want to integrated this code into the source tree
before these points have been clarified.
Ralf
Return-Path: <gregmatu at poczta.onet.pl>
Mailing-List: contact rtems-users-help at rtems.com; run by ezmlm
Delivered-To: mailing list rtems-users at rtems.com
Received: (qmail 548 invoked from network); 6 Mar 2004 20:25:55 -0000
Received: from unknown (HELO smtp1.poczta.onet.pl) (213.180.130.31)
  by 0 with SMTP; 6 Mar 2004 20:25:55 -0000
Received: from vpdn.adm.onet.pl ([213.180.131.58]:4868 "EHLO
	waw03217173.visp.energis.pl") by ps1.test.onet.pl with ESMTP
	id <S677539AbUCFTE1>; Sat, 6 Mar 2004 20:04:27 +0100
Date:	Sat, 6 Mar 2004 20:08:27 +0100
X-Mailer: The Bat! (v1.41) UNREG / CD5BF9353B3B7091
Reply-To: Gregory Matus <gregmatu at poczta.onet.pl>
X-Priority: 3 (Normal)
Message-ID: <12839.040306 at poczta.onet.pl>
To:	rtems-users <rtems-users at rtems.com>
Subject: missing function in 4.6.0
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
Hi all,
I just downloaded and compiled rtems 4.6.0 bsp i386/pc486.
When I tried to build application using PCI I
got error from linker that function BusCountPCI
called in BSP_pciFindDevice is not found.
Is there available patch for this?
And second question: I want to look (only) what bugs are
reported and when I tried to look at so called gnats database page
I was asked about login and password. So question: where can I
saw this reported problems/bugs?
Gregory Matus
