fdsdos problems
Adriano Verardo a.verardo at tecmav.fastwebnet.it
Mon Mar 8 17:51:35 UTC 2004
Hi, all
I'm trying to mount the primary master HD on a PC motherboard
(BSP=pc386) but the operation fails with all disks I connect. All of
them are DOS-formatted. Using different mix DOS versions/HD model
doesn't solve the problem.
Tracking the code I see that RTEMS uses the BPB within the MBR but finds
wrong data.
I verify also that RTEMS always reads the data effectively on the HD, so
the problem seems to be the initialization of the HD. Correct ?
If yes, can anyone kindly explain to me how to initialize it ?
Thank you in advance.
A. Verardo
