DOSFS problems
Adriano Verardo a.verardo at tecmav.fastwebnet.it
Mon Mar 8 20:17:05 UTC 2004
Hi, Angelo
Thank you for the reply.
> I am also using DOSFS on PC386 without problems
I'm sure you are, but I'm not able to. It's clear that I'm doing
something wrong.
Is it correct to use disks formatted by DOS ?
Should MS-DOS and RTEMS-DOSFS see exactly the same files ?
Adriano
