I'm having trouble installing RTEMS on my build-host
kmedri kmedri kmedri at hotmail.com
Tue Mar 16 01:49:49 UTC 2004
>export PATH=/opt/rtems/bin:$PATH.
Yes, I use: "PATH=/opt/rtems-4.6/bin:$PATH"
>Next, you can run command bootstrap in your rtems source directory. All
>builds should be run in build directory.
>From my build directory I ran: "../rtems-4.6.0/bootstrap". I should have
added " -v" but it seems to have completed successfully. I hope I got that
right, "make all install" still results in the error I first posted.
Anything else?
Thanks for the help!
P.S. To check to see if things are miraculously working in the background:
[root at localhost hello_world_c]# make
Makefile:33: /Makefile.inc: No such file or directory
Makefile:35: no file name for `include'
Makefile:36: /make/leaf.cfg: No such file or directory
make: *** No rule to make target `/make/leaf.cfg'.  Stop.
_________________________________________________________________
http://join.msn.com/?pgmarket=en-ca&page=byoa/prem&xAPID=1994&DI=1034&SU=http://hotmail.com/enca&HL=Market_MSNIS_Taglines
