Network Builds
James Yates j.yates at quartzuk.com
Thu Mar 25 14:36:41 UTC 2004
I have taken the latest cs8900 driver you put into the current snapshot using CVS,
updating the necessary files in my working tree. I have created a network sub dir
in my BSP dir and made sure that this is included. I then configure a working tree
using : opt/rtems/rtems-4.6.0/configure --target=sh-rtems \
    --disable-posix --disable-itron --enable-networking --disable-cxx \
    --enable-rtemsbsp=fu0018 \
    --prefix=/opt/rtems/builds/fu0018_net
I then build using make VARIANT=DEBUG, then make VARIANT=DEBUG install.
This is passes fine, so from another shell i then
export RTEMS_MAKEFILE_PATH=/opt/rtems/builds/fu0018_net/sh-rtems/fu0018/
Then I build my application but get the build error:
networkconfig.h:80: `BSP_cs8900_attach' undeclared here (not in a function)
networkconfig.h:80: initializer element is not constant
networkconfig.h:80: (near initialization for `netdriver_config.attach')
I have checked the temporary build tree that was created but in sh-rtems/c/fu0018/lib
/libbsp/sh/fu0018/network  there is just the Makefile and not the files cs8900.c
and cs8900.h that I would have expected to be present.
	Has anyone got any ideas what I might have done wrong?
		James Yates
-----Original Message-----
Sent: 14 March 2004 01:41
To: rtems-users at rtems.com
Cc: Joel Sherrill; James Yates
Subject: Re: Network Builds
Chris Johns wrote:
> Ok, doing it now.
The changes are in cvs mainline.
ccj
