RTEMS: Counting time, again... (help)
Alex
kbyte at iol.pt
Fri Mar 26 10:56:47 UTC 2004
Hi,
I know that will be some users that will say to me that this doubt is already explain in the mailling list, but before sent this mail I search in the mailling list and I saw nothings...
Weel, I need to measure time in microseconds (or nanoseconds, this will be great). Using the posix calls the maximum resolution I get is 20 milliseconds. That doesnt feet my needs... :-(
So, I thinking to use an osciloscope or some device like that to measure those times.
Another idea is to access the hardware ticks.
Which is the best way to measure those times? External counter device or access hardware ticker?
Is there any free source code to access the hardware ticks?
Thanks in advance...
BSP: i686
Alex
___________________________________________________________________________________________
IOL Flash. A net normal em versao acelerada.
Precisa de uma caixa de correio maior? Com o IOL Flash pode ter uma caixa com 21MB de espaco.
Saiba mais sobre o IOL Flash: http://www.iol.pt/central_utilizador/iol_flash/
