gettimeofday(): Help please
sashti srinivasan
svasn_rtems at yahoo.com
Fri Mar 5 12:20:57 UTC 2004
Hello,
Thanks. I will post the sources shortly. It will
be a great help if you help me to solve the other
problem. That is, If I use the functions
Read_timer(), Intialize_timer(), I get the error "raw
handler connexion failed". Is it possible to get away
with it? Same is the case with distributed timing
test tm01.exe.
With Regards
Srinivasan
--- Joel Sherrill <joel.sherrill at OARcorp.com> wrote:
> sashti srinivasan wrote:
> >Hello,
> > With best support from the list, I could have
> my
> >pc386 booting with grub-rtems. In my applications,
> I
> >have posted my problems to the list. I infer that,
> >the error "raw handler connexion failed" is only
> >because of the usage of functions
> Initialize_timer(),
> >Read_timer(). If I do without this by invoking
> >gettimeofday(), I could run the application, but
> >results are not of any use. Because, it appears,
> >gettimeofday() always returns a constant value. It
> >was like this in sparc-rtems(TSIM) also. Please
> help
> >me in getting atleast one of the problems solved.
> I don't know why the pc386 BSP is doing that. But if
> the sparc is
> returning a constant value, then you most likely did
> not configure the
> clock driver.
> Are you defining both these before including
> confdefs.h?
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> Is your test case simple enough to post?
> --joel
> >With Regards
> >Srinivasan
> >__________________________________
> >Do you Yahoo!?
> >Yahoo! Search - Find what youre looking for faster
> >http://search.yahoo.com
Do you Yahoo!?
