gettimeofday(): Help please : SOURCES
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Mar 5 14:17:23 UTC 2004
On the drive in this morning, I had an insight that
turns out to be true.  The clock and timer drivers
on many BSPs use the same timer hardware and cannot be
configured at the same time.  This is certainly
the case for pc386 on CPU models < P5 and the
sparc/erc32.
--joel
sashti srinivasan wrote:
> Hello,
>    I approached the list with following problems:
> (1) "raw handler connexion failed" in pc386.(found to
> be because of usage of functions Timer_initialize(),
> Read_timer())
> (2) gettimeofday() returning constant value.
>    Please help me in getting them solved.  The
> relevant source code is as below.
>   My main file is this.  This is intented to be used
> in both linux and rtems.  I think, I have more problem
> in the next file I used for time measurements.  Help
> me in getting the problems solved.
> /* Posix performance measurement suite
>  * S Srinivasan CS02M040, iitm
> #include <stdio.h>
> #define FORCE_TIMEOFDAY
> #define FOR_RTEMS
>  * The Declaration of main routine depends
>  * on the platform
> #ifdef FOR_RTEMS
> void * RtemsMain(void *arg)
> #else
> #ifdef FOR_UCLINUX
> int MainUclinux()
> #else
> int main(int argc, char **argv)
> #endif
> #endif
>    DoTests();
>    exit(0);
> #ifdef FOR_RTEMS
> #include <bsp.h>
> #define CONFIGURE_POSIX_INIT_THREAD_TABLE
> #define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
> (void*)RtemsMain
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
> #define CONFIGURE_MAXIMUM_POSIX_THREADS 110
> #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 110
> #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 110
> #define CONFIGURE_MAXIMUM_TASKS 120
> #define CONFIGURE_INIT
> #include <confdefs.h>
> #endif
> The following is the file I use for timing
> measurement.  I use three functions.  StartWatch(),
> StopWatch(), ReadWatch().  The first and third are
> similar to Timer_initialize() and Read_timer() (used
> in tmtests) respectively.
> /* Routines used for time measurement *
>  * CS02M040 S Srinivasan IIT(M)       */
> #define FOR_RTEMS
> typedef struct
>         struct timeval atStart;
>         struct timeval atStop;
>         struct timezone notUsed;
>         int watchRunning;
>         long currentTime;
>         char reportText[500][100];
>         int reportLocation;
> }SupportData;
> SupportData sd;
> long TimeDifference(struct timeval tStart, struct
> timeval tEnd)
> #ifndef FORCE_TIMEOFDAY
> #ifndef FOR_RTEMS
>         long seconds,microseconds;
>         seconds=tEnd.tv_sec-tStart.tv_sec;
>         microseconds=tEnd.tv_usec-tStart.tv_usec;
>         microseconds=microseconds+seconds*1000000;
>         return microseconds;
> #else
>         return sd.currentTime;
> #endif
> #else
> #endif
> void StartWatch()
>         sd.watchRunning=1;
> #ifndef FOR_RTEMS
>         gettimeofday(&sd.atStart,&sd.notUsed);
> #else
>         Timer_initialize();
> #endif
> #else
> #endif
> void StopWatch()
> #ifndef FOR_RTEMS
>         gettimeofday(&sd.atStop,&sd.notUsed);
> #else
>         sd.currentTime=Read_timer();
> #endif
> #else
> #endif
>         sd.watchRunning=0;
> long ReadWatch()
>         if(sd.watchRunning==0)
> sd.currentTime=TimeDifference(sd.atStart,sd.atStop);
>         else
>                 sd.currentTime=-1;
> With Regards
> Srinivasan
> __________________________________
> Do you Yahoo!?
> Yahoo! Search - Find what you’re looking for faster
> http://search.yahoo.com
