DOSFS problems
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Mon Mar 8 19:13:16 UTC 2004
Hello Adriano,
can you post more information about your
environment? What RTEMS version are you using,
what are the sizes of your harddisk paritions,
what type of FAT file system do you have there?
How do you try to mount the file systems?
I have adapted the RTEMS DOS-FS to pc386 and
MPC860 hardware, fed my changes back to RTEMS
(they are in 4.6.0 now), and finally had the
impression that things are running fine now.
wkr,
Thomas.
> Hi, all
> I'm trying to mount the primary master HD on a PC motherboard
> (BSP=pc386) but the operation fails with all disks I connect. All of
> them are DOS-formatted. Using different mix DOS versions/HD model
> doesn't solve the problem.
> Tracking the code I see that RTEMS uses the BPB within the MBR but finds
> wrong data.
> I verify also that RTEMS always reads the data effectively on the HD, so
> the problem seems to be the initialization of the HD. Correct ?
> If yes, can anyone kindly explain to me how to initialize it ?
> Thank you in advance.
> A. Verardo
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_keys.htm
