DOSFS problems
Angelo Fraietta afraiett at bigpond.net.au
Mon Mar 8 21:21:49 UTC 2004
Adriano Verardo wrote:
> Hi, Angelo
> Thank you for the reply.
>> I am also using DOSFS on PC386 without problems
> I'm sure you are, but I'm not able to. It's clear that I'm doing
> something wrong.
Have you tried the DOSFS example?
> Is it correct to use disks formatted by DOS ?
Yes
> Should MS-DOS and RTEMS-DOSFS see exactly the same files ?
I found that the filenames had to be in upper case
Goo luck
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
