POSIX equivalent of rtems_timer_fire_after
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Mar 9 17:31:01 UTC 2004
Richard M. Barry wrote:
> I'm rewriting some code that uses a Classic API timer to trigger the excecution of a procedure after a certain amount of time has elapsed, by calling rtems_timer_fire_after(... , rtems_timer_service_routine ,...)
> I want to rewrite the code to only use the POSIX API, so I have to implement an equivalent mechanism. My question is, is the best way to do this:
> 1.Start a POSIX thread (containg the code previously in the rtems_timer_service_routine) that waits for a signal using sigsuspend(), and then
> 2.start a timer that fires the needed signal in my main thread?
> Just making sure I understand the use of sigsuspend() correctly.
Without building a timer server that executes an arbitrary user provided
function, I think that is the only mechanism POSIX provides.
This is one area I think POSIX was weak in.
> Thanks,
> Richard
Return-Path: <vvv at oktetlabs.ru>
Mailing-List: contact rtems-users-help at rtems.com; run by ezmlm
Delivered-To: mailing list rtems-users at rtems.com
Received: (qmail 13142 invoked from network); 9 Mar 2004 17:32:33 -0000
Received: from unknown (HELO smtp.rol.ru) (194.67.21.9)
by 0 with SMTP; 9 Mar 2004 17:32:33 -0000
Received: from ts1-a29.Spb.dial.rol.ru ([195.190.98.29]:30345 "EHLO
oktetlabs.ru" smtp-auth: <none> TLS-CIPHER: <none> TLS-PEER-CN1: <none>)
by gnome05.net.rol.ru with ESMTP id S17616188AbUCIRcc (ORCPT
<rfc822;rtems-users at rtems.com>); Tue, 9 Mar 2004 20:32:32 +0300
Message-ID: <404DFFAD.5040000 at oktetlabs.ru>
Date: Tue, 09 Mar 2004 20:32:29 +0300
Organization: OKTET Labs.
User-Agent: Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.2.1) Gecko/20030225
X-Accept-Language: en, ru
MIME-Version: 1.0
To: Adriano Verardo <a.verardo at tecmav.fastwebnet.it>
CC: rtems-users <rtems-users at rtems.com>
Subject: Re: DOSFS problems
References: <404CD3DC.15836.13FFDC at localhost> <404CF2C0.17667.8C1A6A at localhost> <404DE205.8010908 at tecmav.fastwebnet.it> <404DE41D.9030400 at oktetlabs.ru> <404DF21A.9010306 at tecmav.fastwebnet.it> <404DF8A3.9010500 at oktetlabs.ru> <404DFD6A.3080507 at tecmav.fastwebnet.it>
In-Reply-To: <404DFD6A.3080507 at tecmav.fastwebnet.it>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 7bit
What we are talking about?
MBR - master boot record - stored in very first block of hard disk.
It contains the boot code and partition table at the block end.
Fragment
0x000-0x002 Jump instruction
0x003-0x00A 8 bytes OEM String ("MSDOS 5.0", for example)
0x00B-0x00C Bios Parameters Block - BytesPerSector
Usually 00 20 = 512 and not 07 50 = 20.487
0x00D-... Other BPB, Boot code etc etc.
is a layout of first block of the active hard disk partition.
Boot loader in the MBR read the partition table, find active partition
and load boot loader at the start of active partition. Boot loader
in partition continue to boot OS stored in the partition.
Boot loader of DOS partition should look like you described, i.e.
BPB - BIOS Parameter Block should be stored in the beginning.
I mean, no OEM signature, BPB and so on expected to be in the
MBR.
Or I have missed something?
Victor
Adriano Verardo wrote:
> Victor V. Vengerov wrote:
>> Adriano,
>> As I remember, partition table is located at the end of first block.
>> Fragment you show looks like Intel boot loader code.
> The fragment shoul be:
> 0x01BE... Partition table
> 0x1FE Signature (55 AA)
> DOSF requires a correct (512/1024/2048) value at 0x00B/C, so breaks
> before
> trying to access the other data ...
> Adriano
Victor V. Vengerov
OKTET Labs.
Phone: mobile +7 812 9389372, home +7 812 4281653
