bug in Intel 8255x ethernet controller driver (if_fxp.c)
Ralf Corsepius corsepiu at faw.uni-ulm.de
Tue Mar 16 10:32:25 UTC 2004
On Tue, 2004-03-16 at 11:10, Eugene Denisov wrote:
> Hello all.
> Recently I attempted to use RTEMS 4.6.0pre5 'if_fxp' driver for Intel
> EEPro100+ adapter (PCI IDs: 0x8086 / 0x1229).
> Original drier doesn't wor so I made two modifications in the driver:
> First I uncomment PCI ID for this adapter:
> static struct fxp_ident fxp_ident_table[] = {
>  /* currently untested */
> /* dea: uncommenting i82557 chip */
>         { 0x1229,  "Intel Pro 10/100B/100+ Ethernet" },
Why did you have to do this?
Even Linux uses 0x8086/0x1229 as PCI ids for this card.
IMO, your change either indicates you not using an Intel card or a
massive problem somewhere in RTEMS (Which CPU, which BSP are you
using?).
Ralf
