Network Builds
James Yates j.yates at quartzuk.com
Tue Mar 16 14:53:08 UTC 2004
After doing the configure as shown, I perform a 'make all' followed by a
'make all install'. I then use
export RTEMS_MAKEFILE_PATH=/opt/rtems/builds/fu0018_net/sh-rtems/fu0018/
Then in the app directory I perform a make clean followed by a make
VARIANT=DEBUG.
  I should mention that this is all done under CYGWIN.
	I guess this is probably a problem with either the BSP or CPU
port I have done, but I am completely stumped.
		James
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: 16 March 2004 14:44
To: James Yates
Cc: Chris Johns; rtems-users at rtems.com
Subject: Re: Network Builds
James Yates wrote:
>I have built the new cs8900 driver into rtems using:
>/opt/rtems/rtems-4.6.0/configure --target=sh-rtems \
>    --enable-posix --enable-networking --disable-cxx \
>    --enable-rtemsbsp=fu0018 \
>    --prefix=/opt/rtems/builds/fu0018_net
>When I build a network app based on the netdemo tests, I get warnings
>and so cannot build the app. I get implicit declaration warnings for
>functions such as listen, connect, send etc. I have included
>rtems/rtems_bsdnet.h but it warns me that the directory
>/opt/rtems/sh-rtems/sys-include doesn't exist.
>     Can anyone help?
How are you trying to compile the network demos?  You have to install
the BSP and
then use the provided Makefile after setting RTEMS_MAKEFILE_PATH to
something like /opt/rtems/builds/fu0018_net/
>		James Yates
>From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
>Sent: 15 March 2004 17:38
>To: James Yates
>James Yates wrote:
>>Port I have done is for a custom board based around an SH2 7145f cpu.
>I
>>am still in the process of testing what I have so far, but I can build
>a
>>very basic application with 3 tasks, plus main, each task simply
>>flashing an LED but using a semaphore to block each task. I also have
>>the serial driver implemented so that all 4 on-board UARTs can be
>used.
>>I do however have problems with getting the console to work, although
>I
>>think this is just a misunderstanding on my part.
>I should have already asked... if you have any specific questions or
>issues, ask on the list.  There are plenty of people here who might
>shed some insight.
>Eventually, whatever changes you have which to libcpu/sh would be
>welcome.
>>   I haven't done any major work on this, it is simply based on the
>>SH7045 although I have made some changes. At the moment I have rtems
>>applications running via serial connected gdb through a standard GDB
>>stub on the board that was based on the gdb_stubs project.
>There is some shared code (libbsp/shared) which might be useful
>if you want to add thread awareness.
>>Sent: 10 March 2004 12:25
>>To: James Yates
>>James Yates wrote:
>>>That would be great. Although I have attempted a cpu and bsp port for
>>>rtems, I am still a relative newbie, so any help is very much
>>>appreciated.
>>What CPU?  Is it a new family?
>>>	Many thanks in advance.
>>>		James Yates
>>>From: Chris Johns [mailto:cjohns at cybertec.com.au]
>>>Sent: 10 March 2004 06:21
>>>To: James Yates
>>>Cc: rtems-users at rtems.com
>>>James Yates wrote:
>>>>Can anyone also point me in the direction of some
>>>>more information on using the CS8900 driver located in libchip.
>>>I have an updated libchip driver for the CS8900 with a new readme
that
>>I
>>>hope helps. It provides the missing doco I think you are looking for.
>>>I have cleaned up some driver issues when getting support for DIMMPC
>>>(pc386) working and so may break some existing users of the driver.
>The
>>>changes are worth making.
>>>Joel, is it ok if I commit the changes to head ?
