RTEMS vs Linux : Performance analysis : Comments andSuggestions Please
Ranjith Mukundan
ranjith.mukundan at wipro.com
Fri Mar 19 10:59:54 UTC 2004
and i guess this is without the RT or RTAI patch?? as ralf indicated,
please provide the details (kernel version, patches & patch levels used
etc)..
-----Original Message-----
From: Ralf Corsepius [mailto:ralf_corsepius at rtems.org]
Sent: Friday, March 19, 2004 4:20 PM
To: sashti srinivasan
Cc: RTEMS Users
Subject: Re: RTEMS vs Linux : Performance analysis : Comments
On Fri, 2004-03-19 at 10:47, sashti srinivasan wrote:
> Hello All,
> Because of the full fledged support from the
> list, I am now able to measure time accurately with 1
> microsecond accuracy on PC386. I have got some
> figures of merit, based on this I want to improve the
> performance of rtems. Here are the results for
> discussion. This is a comparison between linux and
> rtems on pc386 platform. POSIX api is used for the
> measurement and to the best possible extent same code
> has been used in both.
More details, please.
How did you measure these figures?
Which CPU has been used?
Which compilers, which flags have been used to compile the Linux-Kernel,
Linux-libc, Linux-application, RTEMS and your RTEMS application?
> Please suggest some way of
> improving the performance of rtems in these aspects.
Number one source of improvement for RTEMS: The compiler flags.
There, choosing the appropriate set of flags can result into huge
differences in performance.
> (All Times are in microseconds : Average of some large
> number of operations)
> Linux RTEMS
> Time To Lock a Mutex = 0.12 0.30
> Time To Unlock a Mutex = 0.12 0.28
> Initialize a Semaphore = 0.31 0.99
> Destroy a Semaphore = 0.10 1.46
> Semaphore Wait = 0.20 0.24
> Semaphore Post = 0.19 0.31
These figures are no actual surprize to me, because Linux pthread
implementation is pretty low-level, lean and highly optimized for speed,
while RTEMS's pthreads/posix implementation is a wrapper to RTEMS native
mechanisms and therefore is comparatively heavy weighted.
> Thread Switching Time = 9.85 1.81
Note this figure above. mutexes and semaphores are only one side of the
medal ;)
> Please suggest some ideas regarding improvement of
> mutex and semaphore performance of rtems.
Ralf
Confidentiality Notice
The information contained in this electronic message and any attachments to this message are intended
for the exclusive use of the addressee(s) and may contain confidential or privileged information. If
you are not the intended recipient, please notify the sender at Wipro or Mailadmin at wipro.com immediately
and destroy all copies of this message and any attachments.
