changes for C++ constructors on psim
JP Bonn rtemsmail at jpbonn.eioMAIL.com
Thu May 6 05:14:13 UTC 2004
I noticed the duplication of the make-exe after I attached the message
it's supposed to be
+ define make-cxx-exe
+         $(LINK.cc) $(AM_CFLAGS) $(AM_CXXFLAGS) $(AM_LDFLAGS) -o
$(basename $@).exe \
+             $(LINK_OBJS) $(LINK_LIBS)
+         $(NM) -g -n $@ > $(basename $@).num
+         $(SIZE) $@
+ endef
I created a bug per Chris's request and attached the patch (with the
above change) to it. When I get some time I'll get the CVS
tree, incoporate the changes and make a formal patch.
> Comments interspersed ...
> On Thu, 2004-05-06 at 00:08, JP Bonn wrote:
> > This is against the 4.6.1 release.  I plan on making a formal patch
> but
> > it'll be a little bit.  These changes make the cdtest program,
> including
> > iostreams, work on psim. There are also changes to cdtest that are
> > independent of the psim changes that allow it to compile if
> iostreams
> > are used.
> > I wanted someone who understand RTEMS to check that I was setting
> flags
> > in the proper files. The linker script changes are the same as some
> of
> > the other bsps.
> > diff -N -P -r -c rtems-4.6.1/c/src/lib/libbsp/powerpc/psim/bsp_specs
> > rtems-4.6.1.mod/c/src/lib/libbsp/powerpc/psim/bsp_specs
> > *** rtems-4.6.1/c/src/lib/libbsp/powerpc/psim/bsp_specs	Fri Aug 22
> > 11:50:48 2003
> > --- rtems-4.6.1.mod/c/src/lib/libbsp/powerpc/psim/bsp_specs	Tue May
> 4
> > 14:14:06 2004
> > *** 10,21 ****
> >   %{!qnolinkcmds: -T linkcmds%s}}}
> >   *startfile:
> > ! %{!qrtems: %(old_startfile)} %{!nostdlib: %{qrtems:  ecrti%O%s \
> >   %{!qrtems_debug: start.o%s} \
> >   %{qrtems_debug: start_g.o%s}}}
> >   *endfile:
> > ! %{!qrtems: %(old_endfile)} %{qrtems: ecrtn%O%s}
> >   *link:
> >   %{!qrtems: %(old_link)} %{qrtems: -Qy -dp -Bstatic -e _start -u
> __vectors}
> > --- 10,21 ----
> >   *startfile:
> > crtbegin%O%s \
> >   *endfile:
> > ! %{!qrtems: %(old_endfile)} %{qrtems: crtend%O%s ecrtn%O%s}
> >   *link:
> __vectors}
> Well, there had been similar proposals to other BSPs, before ... and
> they are causing me some headaches.
> IMO, such crt* handling should be added to gcc (i.e. to specs) instead
> of bsp_specs, because gcc's crt*-stuff is shared for all BSPs.
> Instead of adding crt*-stuff to BSPs' *startfile, *endfile, I'd prefer
> to see the BSP's *startfile, *endfile etc. use the original
> %(startfile), %(endfile), etc.
> Unfortunately, I haven't found enough time to try implementing,
> therefore don't really know if it is possible,  and of cause don't
> have
> a patch proposal at hand.
> > diff -N -P -r -c rtems-4.6.1/c/src/tests/samples/cdtest/main.cc
> > rtems-4.6.1.mod/c/src/tests/samples/cdtest/main.cc
> > *** rtems-4.6.1/c/src/tests/samples/cdtest/main.cc	Thu Sep  4
> 11:46:30 2003
> > --- rtems-4.6.1.mod/c/src/tests/samples/cdtest/main.cc	Tue May  4
> > 14:14:06 2004
> > *** 29,37 ****
> >   #include <stdio.h>
> >   #include <stdlib.h>
> >   #ifdef RTEMS_TEST_IO_STREAM
> > ! #include <iostream.h>
> >   #endif
> >   extern "C"
> >   #include <tmacros.h>
> > --- 29,47 ----
> >   #include <stdio.h>
> >   #include <stdlib.h>
> > ! #include <iostream>
> >   #endif
> > + void my_ctor (void) __attribute__ ((constructor));
> > + void
> > + my_ctor (void)
> > + 	                printf ("hello before main()\n");
> As Chris already mentioned, C constructors are a GCC extension.
> Therefore this function should be guarded by __GNUC__ #defines.
> Also, you are adding "my_ctor" to a C++ file, i.e. you actually are
> attributing a C++ function as constructor. If you want to test C
> constructors, this function should be put into a separate *.c file, or
> be marked 'extern "C"'.
> Another issue is the '__attribute__(..)'.
> This is a GCC internal define. If you want the code to be portable you
> have to define it for non-GCC compilers.
> >   extern "C"
> > *** 134,141 ****
> > ! AClass foo( "GLOBAL" );
> > ! BClass foobar( "GLOBAL" );
> >   void
> >   cdtest(void)
> > --- 144,151 ----
> > ! AClass fooAClass( "GLOBAL fooAClass" );
> > ! BClass fooBClass( "GLOBAL fooBClass" );
> >   void
> >   cdtest(void)
> > *** 144,150 ****
> >       BClass bleak;
> > !     cout << "Testing a C++ I/O stream" << endl;
> >   #else
> >       printf("IO Stream not tested\n");
> >   #endif
> > --- 154,160 ----
> >       BClass bleak;
> > !     std::cout << "Testing a C++ I/O stream" << std::endl;
> >   #else
> >   #endif
> > diff -N -P -r -c rtems-4.6.1/make/custom/psim.cfg
> > rtems-4.6.1.mod/make/custom/psim.cfg
> > *** rtems-4.6.1/make/custom/psim.cfg	Tue May 14 08:51:29 2002
> > --- rtems-4.6.1.mod/make/custom/psim.cfg	Tue May  4 14:25:24 2004
> > *** 15,27 ****
> >   #  This contains the compiler options necessary to select the CPU
> model
> >   #  and (hopefully) optimize for it.
> > ! CPU_CFLAGS = -mcpu=603e -D_OLD_EXCEPTIONS -Dppc603e
> >   #-ffunction-sections
> >   # optimize flag: typically -0, could use -O4 or -fast
> >   # -O4 is ok for RTEMS
> >   # NOTE: some level of -O may be actually required by inline
> assembler
> >   CFLAGS_OPTIMIZE_V=-O4 -fno-keep-inline-functions
> >   define make-exe
> >   	$(LINK.c) $(AM_CFLAGS) $(AM_LDFLAGS) -o $(basename $@).exe \
> > --- 15,35 ----
> model
> -D__USE_INIT_FINI__
> __USE_INIT_FINI__ is a gcc-internal define and is supposed to be
> implicitly supplied by the compiler and should not be used on the
> command-line.
> If your compiler doesn't implicitly specify it, this would indicate a
> bug in the compiler.
> assembler
> > + define make-exe
> > + 	$(LINK.c) $(AM_CFLAGS) $(AM_LDFLAGS) -o $(basename $@).exe \
> > + 	$(SIZE) $@
> > + endef
> >  define make-exe
> Here, you are adding a second "define make-exe". There may only be
> one.
> Ralf
The best kept secret in e-mail.
http://eioMAIL.com
