bochs 2.1.1 & vmware & rtems 4.6.1
Sebastian Fischmeister fischmeister at softwareresearch.net
Thu May 6 18:12:52 UTC 2004
Hello.
   I managed to get bochs running rtems stuff. So I ran the sample programs
(pc386 and pc686).
hello... works
fileio... crashes when invocating the shell
ticker... works
paranoia... fails?
unlimited... fails
minimum... worked with pc386, fails with pc686 (no output)
please see below for detailed output.
Now my question is: what is the problem?
Is it somewhere in the toolchain (gcc cross compiler) or is it bochs (well
paranoia should work then)?
Also did someone manage to get VMWare up and running with rtems? I can start
it, however, I do not get an output (similar to bochs when the ips is not
configured).
Thanks a lot,
  Sebastian
(last screen from fileio)
 started.
task 6 ending.
 TEST1 : creating task 'aa07', number =   7, id = 0a010005, starting, task 7
has
 started.
task 7 ending.
 TEST1 : creating task 'aa08', number =   8, id = 0a010002, starting, task 8
has
 started.
task 8 ending.
 TEST1 : creating task 'aa09', number =   9, id = 0a010003, starting, task 9
has
 started.
task 9 ending.
 TEST1 : creating task 'aa10', number =  10, id = 0a010004, starting, task
10 ha
s started.
 TEST1 : creating task 'aa11', number =  11, id = 0a010005, starting, task
11 ha
s started.
 TEST1 : creating task 'aa12', number =  12, id = 0a010002, starting, task
12 ha
s started.
 TEST1 : creating task 'aa13', number =  13, id = 0a010003, starting, task
13 ha
s started.
 TEST1 : creating task 'aa14', failure, too many.
 FAIL1 : the number of tasks does not equal the expected size -
           task created = 14, required number = 5
EXECUTIVE SHUTDOWN! Any key to reboot...
                                                    ************ FAULTY
THREAD W
ILL BE DELETED **************
       Exception 6 caught at PC 15214D by thread 167837700
                                    Processor execution context at time of
the f
ault was  :
        EAX =
27AE
AEFF    EBX = 2A85  ECX = 148900    EDX = FFFFFFFF
                                                   ESI = 1590B0 EDI = 151FB4
EBP = 151CB0    ESP = 151C84
      Error code pushed by processor itself (if not 0) = 0
                                     ************ FAULTY THREAD WILL BE
DELETED
(last screen from paranoia)
ERROR: Severity: FAILURE:  Comparisons involving +--Inf, +-Inf
and +-0 are confused by Overflow.
ERROR: Severity: SERIOUS DEFECT:    X / X differs from 1 when X = -Inf
  instead, X / X - 1/2 - 1/2 = NaN .
0.000000000000
00000e+00
What message and/or values does Division by Zero produce?
    Trying to compute 1 / 0 produces ...  Inf .
    Trying to compute 0 / 0 produces ...  NaN .
The number of  FAILUREs  encountered =       4.
The number of  SERIOUS DEFECTs  discovered = 4.
The number of  DEFECTs  discovered =         3.
The number of  FLAWs  discovered =           2.
The arithmetic diagnosed has unacceptable Serious Defects.
Potentially fatal FAILURE may have spoiled this program's subsequent
diagnoses.
END OF TEST.
*** END OF PARANOIA TEST ***
