TR : Possible GCC bug on m68k
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Nov 2 21:07:33 UTC 2004
Etienne Fortin wrote:
> Hi everyone,
> I know I should put this on the GCC forum, but I want to be sure that
> I'm not mystaken with the behavior I'll describe.
> I have the following code:
>     packet->number = (unsigned char)fgetc(sender);
>     comp = (unsigned char)fgetc(sender);
>     if(packet->number != ~comp)
>         return EIO;
> packet->number = 0 and comp = 0xFF.
You do not show types of the various elements in the above fragment
so I can't say.  What are packet->number and comp?
I suspect they are 32-bit unsigned integers and with that the behavior
you are describing seems correct.  The (unsigned char) is truncating
the return from fgetc() but the "=" is promoting it to the unsigned
32-bit integer.  When you ~comp, you flip the upper 24-bits and
there you have it.
> We would presume that return EIO will NOT be taken. But in fact, it is.
> I dissaembled the code and found out that the compiler generated a
> comparison between d0 and d1 register, and that d0=0x00000000 and
> d1=0xFFFFFF00!!! It seems that the code generated by GCC assumes words
> when bytes are compared. The compiler should generate code that make
> sure only the byte of the register is significant in the comparison. But
> it does not.
> Is it a bug? a known behavior? A newbie thing? :)
> And by the way, modifying the above code like this makes it work:
>     if(packet->number != (~comp & 0xFF))
>         return EIO;
> Etienne Fortin
> Sensio
