TR : Possible GCC bug on m68k
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Nov 2 21:25:50 UTC 2004
Etienne Fortin wrote:
> Hi Joel,
> Packet->number and comp are defined as unsigned char also.
Sounds like a bug to me.  Can you cut this down to an
extremely small test case that does it?  If you
can do it without the library calls that would be great.
Even if you have to define your own function with
similar prototype.
What gcc is this?
> Etienne
> -----Message d'origine-----
> De : Joel Sherrill <joel at OARcorp.com> [mailto:joel.sherrill at OARcorp.com]
> Envoyé : 2 novembre, 2004 16:08
> À : Etienne Fortin
> Cc : rtems-users at rtems.com
> Objet : Re: TR : Possible GCC bug on m68k
>>Hi everyone,
>>I know I should put this on the GCC forum, but I want to be sure that
>>I'm not mystaken with the behavior I'll describe.
>>I have the following code:
>>    packet->number = (unsigned char)fgetc(sender);
>>    comp = (unsigned char)fgetc(sender);
>>    if(packet->number != ~comp)
>>        return EIO;
>>packet->number = 0 and comp = 0xFF.
> You do not show types of the various elements in the above fragment so I
> can't say.  What are packet->number and comp?
> I suspect they are 32-bit unsigned integers and with that the behavior
> you are describing seems correct.  The (unsigned char) is truncating the
> return from fgetc() but the "=" is promoting it to the unsigned 32-bit
> integer.  When you ~comp, you flip the upper 24-bits and there you have
> it.
>>We would presume that return EIO will NOT be taken. But in fact, it
>>is.
>>I dissaembled the code and found out that the compiler generated a
>>comparison between d0 and d1 register, and that d0=0x00000000 and
>>d1=0xFFFFFF00!!! It seems that the code generated by GCC assumes words
>>when bytes are compared. The compiler should generate code that make
>>sure only the byte of the register is significant in the comparison.
>>But it does not.
>>Is it a bug? a known behavior? A newbie thing? :)
>>And by the way, modifying the above code like this makes it work:
>>    if(packet->number != (~comp & 0xFF))
>>        return EIO;
>>Etienne Fortin
>>Sensio
