cvs
D. Peter Siddons siddons at bnl.gov
Wed Nov 3 17:51:55 UTC 2004
Thanks Joel. Does your comment about gcc3.3.5 mean that it is still a
bit flaky? (I'm working on Coldfire).
One more little thing; the web page telling how to retrieve from the cvs
site tells you to use a password. In fact, the password doesn't work,
you have to use a null password (i.e. just hit <CR>).
Pete.
Joel Sherrill wrote:
> D. Peter Siddons wrote:
>> Hi all,
>>   I want to try to add a bsp to the rtems tree for eventual submission.
>>> From discussions on the list, I gather that the place to do this is
>>> into
>> the cvs development branch (i.e. 4.7). I was able to get the tree
>> from the repository OK, but I need advice on which tools to download
>> for this branch.
> If you are on Linux, you can use apt or yum and fetch the patckages
> that way.  For an RPM to install the info for the RTEMS apt
> repository:
> http://www.rtems.com/ftp/pub/rtems/linux/redhat/7.3/i386/rpms/rtems-4.7/rtems-4.7-apt-conf-0.0-0/
> The newest RTEMS RPMs that I am currently testing with
> are (and replace sparc with your CPU):
> $ rpm -qg RTEMS/4.7 | grep sparc
> rtems-4.7-sparc-rtems4.7-gdb-5.2-2
> rtems-4.7-sparc-rtems4.7-binutils-2.15-1
> rtems-4.7-sparc-rtems4.7-gcc-gcc3.3.5newlib1.12.0-2
> rtems-4.7-sparc-rtems4.7-c++-gcc3.3.5newlib1.12.0-2
> $ rpm -qg RTEMS/4.7 | grep auto
> rtems-4.7-autoconf-rtems-2.59-2
> rtems-4.7-automake-rtems-1.9.2-1
> Ralf is testing newer versions of everything.
> Right now, I want to get a 3.3.5 that I am reasonably satisfied with
> before moving on to territory that is probably more broken.
> The latest tools are available from here if you are not using apt/yum.
>> The download helper doesn't have a 4.7 entry (anyway, it doesn't seem
>> to be functional at the moment, it returns an empty list for any
>> release listed).
> Grrr... I broke it adding 4.6.2 and no one reported it.  I accidentally
> did not have a ";;" at the end of a case option.  It should be fixed now.
>> Any advice on which versions to use?
> See above.  I suppose I need to fix dl-helper to give you a hint
> on snapshots.  But yum is the ticket.
>> Pete.
