Console problem update
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Nov 4 20:20:39 UTC 2004
Etienne Fortin wrote:
> Hello all, its me again, the console guy :)
> Little update for the ones that have an interest, or wish to help me on
> that matter.
Is your interrupt an RTEMS ISR or a raw one directly connected to
hardware?  If you do not go through the RTEMS ISR wrapper, you will
NEVER schedule out of an interrupt.
Also are you sure you are geting the serial port interrupts?
> I tricked RTEMS to release the semaphore at each clock tick to make sure
> the semaphore was the problem. And surprise surprise! It still hang in
> the idle thread!!!!!!!!!
> Theory: My task/scheduler/... config is fu***d up. Anyone here thinks it
> can be possible? For what I know of the problem so far, it seems that as
> soon as the idle thread is entered, no other thread ever gets
> executed... Really seems a config problem to me...
> Idea someone?
> Etienne Fortin
> Sensio
