Console problem update
Etienne Fortin etienne.fortin at sensio.tv
Fri Nov 5 19:33:01 UTC 2004
Tadam!!!!!
I'm FINALLY getting somewhere!
It was now hanging on packet number 13... 13... Hmmm.... Looks like the
CR character. And where does it was throwing an error? In the
packet_number/comp_packet_number test. It appears that whatever a 13 was
encountered, termios was creating a matching 10, f***g up my data!
Ok now there's still some work to do, but it seems to start to look like
something.
Oh my, where would I be without open source RTEMS! :)
Etienne
-----Message d'origine-----
De : Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
Envoyé : 5 novembre, 2004 14:29
À : Etienne Fortin
Objet : RE : RE : RE : RE : RE : RE : RE : Console problem update
Etienne,
first thing first: If head is "behind" tail, if is
still beyond, but has reached the physical end of
the ring buffer and therefore started over at the
beginning (its a ring...).
Second: I suspect my code snipplet some days ago is
not sufficent for your port :-(((
Your "c_iflag" selects XON/XOFF flow control for the
output. I don't think this is a good idea.
And your c_oflag has MANY bits set, which really
doesn't make sense. did you miss a "&" in a
expression like:
c_oflag &= ~(OPOST|.....)
Look into a termios man page and clear all the
c_oflag options you don't need. I would even guess
(oh no, not again!) that c_oflag=0 would be nice for
you...
Hm, maybe this makes things a bit better...
wkr,
Thomas.,
> Hi Thomas,
> Thanks again for your help.
> And no, I really don't think that termios is the problem. To the
> contrary, it looks like a well proven design that worked for all of
> you.
> But, the problem is really nasty, like you said, and there's so much
> possibility regarding the cause of all this!
> An update:
> With HW flow control (driving RTS only and don't care for CTS since
> it's not correctly routed on the m5282lite from Axiom), I don't get
> any more buffer overrun. But, it continue to hang after about 12k (8k
> for another file, probably something else with another) with the
> following values in
> rtems_termios_tty:
> $2 = {forw = 0x0, back = 0x0, refcount = 3, major = 1, minor = 0, isem
> = 436273159, osem = 436273160, cbuf = 0x80d537e4 "", ccount = 0,
> cindex = 0, column = 0, read_start_column = 0, termios = {c_iflag =
> 8450, c_oflag = 4294967230, c_cflag = 2147485885, c_lflag = 32768,
> c_line = 0 '\0', c_cc =
> "\003\034\177\025\004\n\001\000\021\023\032\000\022\017\027\026\000\00
> 0"
> }, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d53c7c
> "\001\220\020\001\001\037c\002\001Ä\204", Head = 840, Tail = 1203,
Size
> = 2048, Semaphore = 436273162}, rawInBufSemaphoreOptions = 0,
> rawInBufSemaphoreTimeout = 100, rawInBufSemaphoreFirstTimeout = 0,
> rawInBufDropped = 0, rawOutBuf = {theBuf = 0x80d53870 "\n\nC3D 1.0.0
> File Tranfer Test\nNeed a valid FAT12 file system on /dev/nvram0 (run
> fs_create).\n\nMount DOSFS file system on /dev/nvram0 (run fs_create
> before)\nfsmount: mounting of \"/dev/nvram0\" to \"/mnt/"..., Head =
> 395, Tail = 395, Size = 1024, Semaphore = 436273161}, t_dqlen = 0,
> rawOutBufState = rob_idle, device = {firstOpen = 0x17ec
> <console_first_open>, lastClose = 0x1848 <console_last_close>,
pollRead
> = 0, write = 0x1722 <console_interrupt_write>, setAttributes = 0x1772
> <console_set_attributes>, stopRemoteTx = 0x1794
> <console_stop_remote_tx>, startRemoteTx = 0x17c0
> <console_start_remote_tx>, outputUsesInterrupts = 1}, flow_ctrl = 256,
> lowwater = 1024, highwater = 1536, rxTaskId = 0, txTaskId = 0, t_line
> 0, t_sc = 0x0, tty_snd = {sw_pfn = 0, sw_arg = 0x0}, tty_rcv = {sw_pfn
> 0, sw_arg = 0x0}, tty_rcvwakeup = 0}
> As you can see, no data dropped at all (rawInBufDropped == 0). But,
> Head == 840 && Tail == 1203... What does this mean? There's 1203-840
> characters in the buffer? Shouldn’t be since you said that Tail < Head
> means characters in the buffer. So it means there's 1203-840 places
> available in the buffer?
> And for a file it hang in the semaphore, for anothers it bump out of
> my Ymodem code with an error... If you want (I would appreciate but
> you already put time into this), could you look at the configuration
> of the termios structure. I suspect something about characters being
> wrongly interpreted somewhere in the flow of data.
> Etienne
> P.S.
> Another file, same behavior:
> $3 = {forw = 0x0, back = 0x0, refcount = 3, major = 1, minor = 0, isem
> = 436273159, osem = 436273160, cbuf = 0x80d537e4 "ò", ccount = 1,
> cindex = 1, column = 0, read_start_column = 0, termios = {c_iflag =
> 0"
> }, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d53c7c "", Head = 197,
> Tail = 1223, Size = 2048, Semaphore = 436273162},
> rawInBufSemaphoreOptions = 0, rawInBufSemaphoreTimeout = 100,
> rawInBufSemaphoreFirstTimeout = 0, rawInBufDropped = 0, rawOutBuf =
> {theBuf = 0x80d53870 "\n\nC3D 1.0.0 File Tranfer Test\nNeed a valid
> FAT12 file system on /dev/nvram0 (run fs_create).\n\nMount DOSFS file
> system on /dev/nvram0 (run fs_create before)\nfsmount: mounting of
> \"/dev/nvram0\" to \"/mnt/"..., Head = 399, Tail = 399, Size = 1024,
> Semaphore = 436273161}, t_dqlen = 0, rawOutBufState = rob_idle, device
> {firstOpen = 0x17ec <console_first_open>, lastClose = 0x1848
> <console_last_close>, pollRead = 0, write = 0x1722
> Envoyé : 5 novembre, 2004 13:41
> À : Etienne Fortin; rtems-users at rtems.com
> Cc : rtems-users at rtems.com
> Objet : RE : RE : RE : RE : RE : RE : Console problem update
> Etienne,
> > The sender of a file in YMODEM waits for an ACK to be received
> > before
> > sending the next packet. So, I can wait forever (at least a little
> > less than the timeout value of YMODEM which is, if I'm not mystaken,
> > about 30
> > seconds) between each packet.
> > And I don't understand why you say hardware flow control would not
> > help. If RTS is negated during transfer because the buffer is about
to
> > get filled completely, then the transmitter (sender) will stop and
> > wait for RTS (its CTS) to get asserted again before continuing. This
> > would ensure that the input buffer never overflow. Am I
understanding
> > correctly or is there something I miss in my comprehension?
> Sorry, this was my fault. For protocols like YModem, HW Flow
> Control might work. I once had problems with HW flow control and
> different protocols.
> Nonetheless I would expect HW flow control to make things even
> more difficult. I guess you are on a ColdFire derivate, and the
> YModem is currently the only application really consuming
> processor load? Then you should definitively have enough
> processing power for a 9.6kBaud line.
> Hm another guess: What do you do with the data received? If you
> start storing it on a Flash Disk (or a real harddisk), things
> might be slow there... So, whenever you perform a "write" call
> to disk, it might wait until the data has been actually written.
> And this might make your communication task stop for several
> milliseconds.  Hmpf. Let me look at it a bit closer. This would
> not make your input buffer overrun. So forget this guess. Hmpf.
> But maybe it would nevertheless make sense to try to write to
> RAMDISK (IMFS) instead. Just to make sure.
> Let me try another run: Maybe it you perform sort of a timed log
> of your protocol implementation, putting additional, self-built
> log calls to specific parts of your protocol implementation
> ("Now I am calling read, now I am back with xx bytes read").
> Maybe you can find out, why your software seems to hang from
> time to time.
> I really don't think it is the termios/console mechanism which
> generates your headache...
> wkr,
> Thomas.
> > Etienne
> > Envoyé : 5 novembre, 2004 12:19
> > À : Etienne Fortin
> > Objet : RE : RE : RE : RE : RE : Console problem update
> > Etienne,
> > > In what situation does the rawInDropped value can increase? I only
> > > see
> > > buffer overrun, but I really don'T have that much experience with
> > > the
> > > console especially on RTEMS. So, do you think that putting
hardware
> > > flow control to work on my faulty board would fix the problem?
> > rawInDropped will be increased whenever a character has been
> > received but there is no more position available in the rawInBuffer.
> > I don't think that any kind of flow control (XON/XOFF, hardware
> > etc) would help you, because in general the protocol itself
> > should have some kind of flow control.
> > When your input buffer has an overflow, obviously you get too much
> > data.
> > filling 1K of input buffer takes about 1 second, so I would think
> > you look too seldomly, whether input data is available...
> > What do you test currently? file stransfers from RTEMS to host or
> > from host to RTEMS?
> > Do you send big chunks of data (let's say a 1K Buffer) in situations
> > when the output buffer is already filled? Then your "write" call
> > will block until the whole new data block can be moved into the
> > rawOutBuffer, and this may take too much time for your input
> > processing...
> > wkr,
> > Thomas.
> > > Etienne
> > > Envoyé : 5 novembre, 2004 11:24
> > > À : Etienne Fortin
> > > Objet : RE : RE : RE : RE : Console problem update
> > > Etienne,
> > > head is always "ahead" of tail in the ring buffer, so when
> > > head==tail+1, there is exactly one char in the buffer. This is ok,
I
> > > would say.
> > > In the last snapshot, you have a bunch of Debug info in the output
> > > buffer, (like "C3D 1.0.0 File Tranfer Test\r\nNeed a valid FAT12
> > > file system on /dev/nvram0 ") I hope this does not happen during
> > > YMOdem transfer?
> > > Sorry for asking, but do you possibly have a flaw in your protocol
> > > engine design? When there are more characters in the input than
> > > expected, do you consume them properly?
> > > Seems to get a weekend with headaches for you ?
> > > wkr,
> > > Thomas.
> > > > Some more info.
> > > > My rawInBuf is now 1024 bytes. And it gives me the same problem:
> > > > Head go beyond Tail in rawInBuf and rawInBufDropped starts to go
> > > > up.
> > > > 0, isem
> > > > = 436273159, osem = 436273160, cbuf = 0x80d53be4 "ò", ccount =
> > > > 1,
{c_iflag
> > > > = 8450, c_oflag = 4294967230, c_cflag = 2237, c_lflag = 32768,
> > > > c_line
> > > > 0 '\0', c_cc =
> > > 0\
> > > 00
> > > 0"
> > > > }, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d5407c "", Head =
> > > > 197,
> > > > Tail = 196, Size = 1024, Semaphore = 436273162},
> > > > rawInBufSemaphoreFirstTimeout = 0, rawInBufDropped = 3,
> > > > rawOutBuf
> > > > {theBuf = 0x80d53c70 "\r\n\r\nC3D 1.0.0 File Tranfer
> > > > Test\r\nNeed
> a
> fs_create).\r\n\r\nMount
> > > > before)\r\nfsmount:
> > > > mounting of \"/dev/nvram0\" to "..., Head = 413, Tail = 413,
Size
> > > > 1024, Semaphore = 436273161}, t_dqlen = 0, rawOutBufState =
> > > > rob_idle, device = {firstOpen = 0x17a8 <console_first_open>,
> > > > lastClose = 0x1804 <console_last_close>, pollRead = 0, write =
> > > > 0x16de <console_interrupt_write>, setAttributes = 0x172e
> > > > <console_set_attributes>, stopRemoteTx = 0x1750
> > > > <console_stop_remote_tx>, startRemoteTx = 0x177c
> 1,
> > > > lowwater = 512, highwater = 768, rxTaskId = 0, txTaskId = 0,
> > > > t_line
> > > 0,
> > > > {sw_pfn
> > > 0,
> > > > Something to do with the absence of hardware flow control?
> > > > And now no matter what file I send, the problem appears at 12k
> > > > for
> > > > a 1024 buffers (sooner for a 128 bytes buffer).
> > > > Etienne
> > > > Envoyé : 5 novembre, 2004 09:56
> > > > Objet : RE : RE : RE : Console problem update
> > > > Etienne,
> > > > a baud rate difference of 2% is still tolerable, as
> > > > fas as I know. And you would be well below.
> > > > I just had another look into the data structure snapshot you
> > > > sent this morning (last night...). To my suprise, the
> > > > "flow_ctrl" fiels is non-zero. The value 512 means, that the
> > > > "input is controlled with XON/XOFF protocol". Maybe you should
> > > > try to clear the "IXON" and "IXOFF" flags in the c_iflag field
> > > > of termios settings?
> > > > wkr,
> > > > Thomas.
> > > > > Hi Thomas,
> > > > > Yes, the buffer is empty. But, it shows that at least 1161
> > > > > characters were received. After that, termios thinks there's
no
> > > > > more data received or it lost sync or something else.
> > > > > I said before that my baudrate is really 9630 and not 9600.
> > > > > The computer is 9600. Do you think that can be the problem?
> > > > > Etienne
> > > > > Envoyé : 5 novembre, 2004 02:23
> > > > > À : Etienne Fortin
> > > > > Objet : RE : RE : Console problem update
> > > > > Etienne,
> > > > > from the data you sent, the input and output buffer really is
> > > > > "empty", (for rawInBuf and rawOutBuf, "Head" and "Tail" have
the
> > > > > same values) but I guess you already saw this.
> > > > > Which BSP are you using? Is it possible your console driver
> > > > > interrupt gets stuck, when there is a receive and transmit
> > interrupt
> > > > > pending at the same time?
> > > > > wkr,
> > > > > Thomas.
> > > > > > Hi Thomas,
> > > > > > Yes a VERY nasty problem... It must have something to do
> > > > > > with
> > > > > > my comprehension and the way I implemented the console
> > > > > > driver...
> > But,
> > > > > > I
> > > > > > was able to make a lot of other things work before (I mean,
> > > > > > the
> > > > > > balance of
> > > > > > RTEMS) and I got nasty problem with RTEMS before. But that
one
> > > > > > is special. Its so stupid! And I hate to work with transfer
> > > > > > protocol.
> > > > You
> > > > > > know you'll be able to make it work, you just don't know
> > > > > > when...
> > > > > > Anyway, here's the snapshot of the rtems_termios_tty
> > > > > > structure
> > > > > > when the semaphore get stuck.
> > > > > > = 0, isem
> > > > > > = 436273159, osem = 436273160, cbuf = 0x80d542a4 "}", ccount
> > > > > > = 0, cindex = 0, column = 0, read_start_column = 0, termios
> > {c_iflag
> > > > > > = 9474, c_oflag = 4294967230, c_cflag = 2237, c_lflag =
> > > > > > 32768, c_line
> > > > > > 0 '\0', c_cc =
> > > > > 6\
> > > > > 00
> > > > > 0\
> > > > > 00
> > > > > 0"
> > > > > > }, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d53a98 "",
> > > > > > Head
> > > > > > 1161, Tail = 1161, Size = 2048, Semaphore = 436273162},
100,
> > > > > > rawOutBuf
> > > > > > {theBuf = 0x80d543b0
> > > > > > "ransfer...\r\n\r\nC\006C.\r\nrawInBuf.Size
> > > > > > 2048\r\nPress a key to begin t", Head = 17, Tail = 17, Size
> > > > > > = 64, Semaphore = 436273161}, t_dqlen = 0, rawOutBufState =
> rob_idle,
> > > > > > device
> > > > > > {firstOpen = 0x17a2 <console_first_open>, lastClose = 0x17ea
> > > > > > <console_last_close>, pollRead = 0, write = 0x16dc
> > > > > > <console_interrupt_write>, setAttributes = 0x172c
> > > > > > <console_set_attributes>, stopRemoteTx = 0x174e
> > > > > > <console_stop_remote_tx>, startRemoteTx = 0x1778
> flow_ctrl
> > > > > > = 512, lowwater = 64, highwater = 96, rxTaskId = 0, txTaskId
> > > > > > 0, t_line = 0, t_sc = 0x0, tty_snd = {sw_pfn = 0, sw_arg =
> 0x0},
> > > > > > tty_rcv = {sw_pfn =
> > > > > 0,
> > > > > > As you can see, I "hardwired" the rawInBuf to be 2048
> > > > > > characters in size. And surprisingly enough, the Head is at
> > > > > > offset 1161.
> > This
> > > > > > mean
> > > > > > that I received the first 130 bytes packet (init packet) and
> > > > > > some
> > > > part
> > > > > > of the first data packet. But for some reason, termios lost
> > > > > > sync and lost all the next characters, stucking the
semaphore
> > > > > > and giving me headaches :)
> > > > > > What do you think???
> > > > > > And by the way, you can't imagine how glad I am to have help
> > > > > > from all of you on RTEMS forum.
> > > > > > Etienne Fortin
> > > > > > Sensio
> > > > > > Envoyé : 4 novembre, 2004 16:09
> > > > > > Objet : RE : Console problem update
> > > > > > Etienne,
> > > > > > can you provide a snapshot of the termios data structures
> > > > > > when
> > > > > > your console input gets stuck? What values do the buffer
> > > > > > pointers
> > have
> > > > > > for the raw input buffer?
> > > > > > What baud rate are you using currently?
> > > > > > What happens, if you write a simple application with two
> > > > > > tasks, one sending a 1K buffer to the console, one receiving
> > > > > > it, and
> > putting
> > > > > > the console into loopback mode (with a nice little wire
> > > > > > between
> > > pin
> > > > > > 2 and 3 of your serial connector)? Does it also hand in that
> > > > > > case?
> > > > > > You really seem to have a nasty problem there...
> > > > > > I have been using termios code for machine interfaces back
> > > > > > with
> > > > > > RTEMS version 4.0.0, and I never had similar problems...
> > > > > > wkr,
> > > > > > Thomas.
> > > > > > > I don'T know why I tought that even after releasing the
> > > > > > > sempahore,
> > > > > > > I was still stuck in the idle thread. To the contrary!
> > > > > > > Forcing the
> > > > > > > release of the semaphore make the task continue to execute
> > > > > > > code and
> > > > > I
> > > > > > > eventually get out of the code with an error (that's ok
> > > > > > > since the semaphore was forced to be released so no valid
> > > > > > > data is there waiting)...
> > > > > > > The question now is why the code is not notified of new
> > > > > > > characters. Is
> > > > > > > it possible that the termios code, being designed for
> > > > > > > "human"
> > > > > > > interraction (at least I presume), can't cope with
sustained
> > > > > > > binary data transfer and so I lost data and eventually the
> > > > > > > semaphore is struck waiting for characters that will never
> > > > > > > come?
> > > > > > > Is it possible?
> > > > > > > Etienne Fortin
> > > > > > > Sensio
> > > > > > > De : Joel Sherrill <joel at OARcorp.com>
> > > > > > > [mailto:joel.sherrill at OARcorp.com]
> > > > > > > Envoyé : 4 novembre, 2004 15:21
> > > > > > > À : Etienne Fortin
> > > > > > > Objet : Re: Console problem update
> > > > > > > Etienne Fortin wrote:
> > > > > > > > Hello all, its me again, the console guy :)
> > > > > > > > Little update for the ones that have an interest, or
> > > > > > > > wish
> > > > > > > > to
> > > > > > > > help me on that matter.
> > > > > > > Is your interrupt an RTEMS ISR or a raw one directly
> > > > > > > connected to hardware?  If you do not go through the RTEMS
> > > > > > > ISR wrapper, you
> > > > will
> > > > > > > NEVER schedule out of an interrupt.
> > > > > > > Also are you sure you are geting the serial port
> > > > > > > interrupts?
> > > > > > > > I tricked RTEMS to release the semaphore at each clock
> > > > > > > > tick
> > > > > > > > to
> > > > > > > > make sure the semaphore was the problem. And surprise
> > > > > > > > surprise!
> > > > It
> > > > > > > > still hang in the idle thread!!!!!!!!!
> > > > > > > > Theory: My task/scheduler/... config is fu***d up.
> > > > > > > > Anyone here thinks it can be possible? For what I know
> > > > > > > > of the problem so far, it
> > > > > seems
> > > > > > > > that as soon as the idle thread is entered, no other
> > > > > > > > thread ever
> > > > > > gets
> > > > > > > > executed... Really seems a config problem to me...
> > > > > > > > Idea someone?
> > > > > > > > Etienne Fortin
> > > > > > > > Sensio
> > > > > > > Joel Sherrill, Ph.D.             Director of Research &
> > > > Development
> > > > > > > joel at OARcorp.com                 On-Line Applications
> Research
> > > > > > > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> > > > > > >     Support Available             (256) 722-9985
> > > > > > IMD Ingenieurbuero fuer Microcomputertechnik
> > > > > > Thomas Doerfler           Herbststrasse 8
> > > > > > D-82178 Puchheim          Germany
> > > > > > email:    Thomas.Doerfler at imd-systems.de
> > > > > > PGP public key available at: http://www.imd-
> > > > > > systems.de/pgp_keys.htm
> > PGP public key available at: http://www.imd- systems.de/pgp_keys.htm
