gen68360 & termios
sebastian ssmoller sebastian.ssmoller at gmx.net
Tue Nov 9 21:47:55 UTC 2004
> > to enable ttyS1 ?
> If the gen68360 BSP supported more serial ports, they would likely
> have been registered by  the console driver.  It only
> registers a single serial port.  Often a single serial port/console
> driver will register multiple serial ports if it can support them
> all.
> AFAIK there is only a single serial port supported so there are
> no more device drivers in the gen68360.
hhmm - ok - so in fact there are two hardware serial ports and the 68360
should support them both (afaik) ...
looking into console/console.c i found lots of code dealing with smc1
but none dealing with smc2 - so this meens to me two things: i am blind
XOR i cannot access ttyS2 with this driver ;-)
but console/console.c would be the right place to add this code right ?
back to the other prob:
> > any ideas while a simple tcgetattr & tcsetattr (without changing
> > anything ) causes my stdout to be broken ?
what about this - i thought just getting and (re)setting the attr's
would have no effect ...
THX,
seb
"Perfection is achieved, not when there is nothing left to add,
but when there is nothing left to take away."
--- Antoine de St. Exupery, Wind, Sand, and Stars, 1939
