gen68360 & termios
sebastian ssmoller sebastian.ssmoller at gmx.net
Tue Nov 9 23:06:59 UTC 2004
On Tue, 09 Nov 2004 23:07:14 +0100
"Thomas Doerfler" <Thomas.Doerfler at imd-systems.de> wrote:
> Sebastian,
> I have an extended version of the gen68360 console driver, it is
> attached to this mail. It supports up to 2 SMCs and 4 SCCs as
> serial devices. Is this enough? :-)
cool :) - much thx - i wil test this as soon as i get access to the
boards again
> > > > any ideas while a simple tcgetattr & tcsetattr (without changing
> > > > anything ) causes my stdout to be broken ?
> > what about this - i thought just getting and (re)setting the attr's
> > would have no effect ...
> Hm. It is broken. hm.
> So, what is broken? Can you be more specific?
hhmm thats a bit difficult ...
so the output looks like the baud rate has changed but of course i havnt
changed anything. anyway, even if i change the baud rate to the correct
value (which is 38400) i get this bogus output.
i should mention that i had to hack things of console/console.c to get
it running:
- first i had to set the default console_baud_rate to 38400 (hardcoded)
  cause i was unable to set it using tcsetattr on system startup
- i had to disable interrupts although i know that smc1 irqs work with
  this board
- and i had to change/comment out the following part of the code:
  m360.pbdir =& 0x0003;
  m360.pbdbr =& 0xff3f;
  m360.brgc1 = M360_BRG_RST;
  m360.brgc1 = smc1BRGC(console_baud_rate);
  i must admit that i never looked up what this code really does - i
  just took i from another project where it work fine *shame*
THX again
regards,
seb
> wkr,
> Thomas.
> > THX,
> > seb
> > "Perfection is achieved, not when there is nothing left to add,
> > but when there is nothing left to take away."
> > --- Antoine de St. Exupery, Wind, Sand, and Stars, 1939
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_keys.htm
