gcc 3.4.2 vs &address == NULL
Aaron J. Grier
aaron at frye.com
Sat Nov 13 00:11:32 UTC 2004
I've been encouraged to bring up another toolchain, and I figured I'd
try and use peter barada's coldfire-hacked gcc 3.4.2. I've got it
compiled up, but ran across an old issue which apparently was never
resolved:
http://sources.redhat.com/ml/crossgcc/2004-08/msg00013.html
in a nutshell, the optimizer on gcc 3.4.2 assumes that the address of a
variable can't be 0, so it optimizes out any checks. as pointed out in
the referenced discussion, this is specifically an issue for
bsp_pretasking_hook in m68kpretaskinghook.c.
here's the fix. (the volatile extern declaration might be overkill.)
Aaron J. Grier | Frye Electronics, Tigard, OR | aaron at frye.com
"Note that many bands' backline amps produce levels exceeding OSHA
standards for industrial facilities. Yet this is considered normal
working conditions for musicians. That's showbiz." -- Scott Dorsey
Index: 0.61/c/src/lib/libbsp/m68k/shared/m68kpretaskinghook.c
--- 0.61/c/src/lib/libbsp/m68k/shared/m68kpretaskinghook.c Fri, 29 Sep 2000 20:11:24 -0700 kaben (rtems/s/b/25_m68kpretas 1.1 644)
+++ 0.61(w)/c/src/lib/libbsp/m68k/shared/m68kpretaskinghook.c Fri, 12 Nov 2004 13:56:27 -0800 aaron (rtems/s/b/25_m68kpretas 1.1 644)
@@ -36,7 +36,7 @@
extern void *_RamBase;
extern void *_WorkspaceBase;
-extern void *_HeapSize;
+extern volatile void *_HeapSize;
unsigned long _M68k_Ramsize;
@@ -44,7 +44,7 @@
void bsp_pretasking_hook(void)
void *heapStart;
- unsigned long heapSize = (unsigned long)&_HeapSize;
+ volatile unsigned long heapSize = (unsigned long)&_HeapSize;
unsigned long ramSpace;
heapStart = (void *)
