gcc 3.4.2 cpu32 patch
Ralf Corsepius ralf_corsepius at rtems.org
Thu Nov 18 06:31:15 UTC 2004
On Thu, 2004-11-18 at 16:19 +1100, Chris Johns wrote:
> Peter Barada wrote:
> > ColdFire code gerneration doesn't key off of either MASK_68020 or
> > MASK_BITFIELD so this change shouldn't change and ColdFire code generation.
> > However, TARGET_CPU_CPP_BUILTINS, does define __m68k__ and m68000 for
> > ColdFire which I think *should* be disabled since the m68k supports
> > instructions/addressing modes that are illegal for ColdFire.
> Ouch.
> > Unfortunately I have no idea how much code is out there that uses
> > these generic 68k preprocessor defines to select code that runs on
> > *both* generic 68k cores as well as ColdFire cores.
> Sure.
> > As a result I'd say that we leave well enough alone :(
> I agree we should keep the defines as they were. So taking a look at gcc
> 3.3.1 we get:
>   $ m68k-rtems-gcc -mcpu32 -dM -E - </dev/null | grep 68020
>   $ m68k-rtems-gcc -m5200 -dM -E - </dev/null | grep 68020
>   $ m68k-rtems-gcc -m68000 -dM -E - </dev/null | grep 68020
With rtems.org's gcc-3.2.3 (Joel's rpms):
$ m68k-rtems-gcc -mcpu32 -dM -E - </dev/null | grep -Ei 'cold|cpu32'
#define __mcpu32 1
#define __mcpu32__ 1
#define mcpu32 1
$ m68k-rtems-gcc -m5200 -dM -E - </dev/null | grep -Ei 'cold|cpu32'
$ m68k-rtems-gcc -m68000 -dM -E - </dev/null | grep -Ei 'cold|cpu32'
$ m68k-rtems-gcc -m68302 -dM -E - </dev/null | grep -Ei 'cold|cpu32'
$ m68k-rtems-gcc -m68332 -dM -E - </dev/null | grep -Ei 'cold|cpu32'
#define __mcpu32 1
#define mcpu32 1
> while with 3.4.3:
>   #define __mc68020__ 1
>   #define __mc68020 1
>   #define mc68020 1
>   $ m68k-rtems-gcc -m68302 -dM -E - </dev/null | grep 68020
>   $ m68k-rtems-gcc -m68332 -dM -E - </dev/null | grep 68020
>   #define __mc68020 1
>   #define mc68020 1
$ m68k-rtems4.7-gcc -mcpu32 -dM -E - </dev/null | grep -Ei 'cold|cpu32'
#define mcpu32 1
#define __mcpu32 1
$ m68k-rtems4.7-gcc -m5200 -dM -E - </dev/null | grep -Ei 'cold|cpu32'
#define __mcoldfire__ 1
$ m68k-rtems4.7-gcc -m68000 -dM -E - </dev/null | grep -Ei 'cold|cpu32'
$ m68k-rtems4.7-gcc -m68302 -dM -E - </dev/null | grep -Ei 'cold|cpu32'
$ m68k-rtems4.7-gcc -m68332 -dM -E - </dev/null | grep -Ei 'cold|cpu32'
#define mcpu32 1
#define __mcpu32 1
> This looks like the defines are not the same and so RTEMS appears
> broken. I am suspect other code will break as a result.
Correct me if I am wrong, but AFAIS, it would be sufficient to extend
RTEMS m68k score to using __mcoldfire__ and __mcpu32__.
Ralf
