MVME230x exception error on boot
Bill Nolan wnolan at bnl.gov
Thu Nov 18 20:11:19 UTC 2004
Hello again,
I am having an exception durring boot of the sample applications.
I saw a thread about this in the archives from last summer, But could
not find how it was resolved.
This is the original thread.
http://www.rtems.com/ml/rtems-users/2003/august/msg00063.html
My configuration is:
 Mvme2308 ( a mvme2307 with 128Mb memory )
We are trying to boot the sample app hello.exe from
rtems-ss-20030703.
No addons or additional softwhare yet.
Thank you again for any help.
-- Bill
below is the console output durring boot.
Welcome to rtems-ss-20030703(PowerPC/PowerPC 604/mvme2307) on MVME 2300
OpenPIC found at C1000000.
pci : Interrupt routing not available for this bsp
Enabling MCP generation on hostbridge errors
OpenPIC Version ? (2 CPUs and 17 IRQ sources) at 0xC1000000
OpenPIC Vendor 0 (Motorola), Device 0 (Raven), Stepping 2
OpenPIC timer frequency is 8333656 Hz
Universe II PCI-VME bridge detected at 0xC1040000, IRQ 11
Universe Master Ports:
Port  VME-Addr   Size       PCI-Adrs   Mode:
0:    0x20000000 0x0F000000 0x10000000 A32, Dat, Sup
1:    0x00000000 0x00FF0000 0x1F000000 A24, Dat, Sup
2:    0x00000000 0x00010000 0x1FFF0000 A16, Dat, Sup
Universe Slave Ports:
0:    0xC0000000 0x07F80000 0x80000000 A32, Pgm, Dat, Sup, Usr
Overriding main IRQ line PCI info with 5
exception handler called for exception 3
         Next PC or Address of fault = 1D17C
         Saved MSR = 3032
         R0 = 0
         R1 = 36E80
         R2 = 2FCD8
         R3 = 3AF30
         R4 = 0
         R5 = 6E59800
         R6 = 30000
         R7 = 10000
         R8 = F
         R9 = 7F368D
         R10 = 10000
         R11 = 1118000
         R12 = 1FE
         R13 = 32924
         R14 = 0
         R15 = 0
         R16 = 0
         R17 = 0
         R18 = 0
         R19 = 0
         R20 = 0
         R21 = 0
         R22 = 3032
         R23 = 2E2A8
         R24 = 10000
         R25 = 30000
         R26 = 1
         R27 = 0
         R28 = 30000
         R29 = 34EB0
         R30 = 7F368D0
         R31 = 3AF30
         CR = 44800042
         CTR = 6E5980
         XER = 20000000
         LR = E0A8
         DAR = 1118000
Stack Trace:
  IP: 0x0001D17C, LR: 0x0000E0A8
--^ 0x00014324--^ 0x0000A620--^ 0x000040E0--^ 0x0000D32C--^ 0x00003CCC
--^ 0x0000321C
unrecoverable exception!!! Push reset button
Bill Nolan.
wnolan at bnl.gov
"You do not examine legislation in the light of the benefits it will
convey if properly administered, but in the light of the wrongs it
would do and the harms it would cause if improperly administered."
       -Lyndon Johnson
