samples
D. Peter Siddons siddons at bnl.gov
Tue Nov 23 14:50:36 UTC 2004
I was able to build the CVS tree for my BSP, but I can't figure out how
to get the samples built. In the 4.6 releases the samples were built
even if --disable-tests was specified, but that doesn't seem to be the
case for 4.7. I tried --enable-tests, but it failed for:
error: No acceptable GNATMAKE found.
.........failed for ada-tests.
Can I select a subset of the tests to build? How do I make the samples?
Pete.
