samples
D. Peter Siddons siddons at bnl.gov
Tue Nov 23 16:46:17 UTC 2004
Hi Eric, Ralf,
    Thanks very much :) Adding '=samples' works fine.
Pete.
Ralf Corsepius wrote:
>On Tue, 2004-11-23 at 09:50 -0500, D. Peter Siddons wrote:
>>I was able to build the CVS tree for my BSP, but I can't figure out how
>>to get the samples built. In the 4.6 releases the samples were built
>>even if --disable-tests was specified, but that doesn't seem to be the
>>case for 4.7. I tried --enable-tests, but it failed for:
>>error: No acceptable GNATMAKE found.
>>.........failed for ada-tests.
>That's a bug, I fixed yesterday or sometime last weekend.
>cvs up and run bootstrap, again.
>>Can I select a subset of the tests to build?
>Partially, yes.
>In CVS-trunk/RTEMS-4.7 you can select between building the "samples",
>building all of the tests and not building the tests.
>--enable-tests or --enable-tests=yes .. enable building all tests.
>--enable-tests=samples .. enable building the "samples" only.
>--disable-tests .. disable building the tests.
>The default for this switch is --enable-tests=samples, i.e. if not
>explicitly specifying --enable-tests, only the "samples" will be built.
>> How do I make the samples?
>cf. above.
>Ralf
