AW: Where to get old toolchains (gcc 2.95)? SOLVED!
Pedot, Wolfgang wpedot at harris.com
Wed Nov 24 17:38:06 UTC 2004
Hi,
after searching the web for ages I finally found a toolchain
arround gcc 2.95.2 on ftp.rtems.com/pub/rtems/releases/4.5.0/c_tools which
builds
my system fine.
The funny thing is that RPM 4.1 is complaining about MD5 Chksum faults
for powerpc-rtems-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm (md5sum checks out), but
the
archive is extractable when using rpm2cpio or RPM 3.0.4.
greetings
Wolfgang Pedot
> -----Ursprüngliche Nachricht-----
> Von: Pedot, Wolfgang [mailto:wpedot at harris.com]
> Gesendet: Dienstag, 23. November 2004 13:41
> An: 'rtems-users at rtems.com'
> Betreff: Where to get old toolchains (gcc 2.95)?
> Hi,
> I have a project here thats based on rtems-ss-20020205 and
> used to be compiled
> with GCC 2.95.2 in a cygwin environment. Now I want that
> project to be built
> on a linux-machine but unfortunately the system does not
> compile because of
> differences
> in the include-files (missing defines, different function
> prototypes...) of the
> new
> and old toolchains. Is there any possibility to get a
> complete cross-toolchain
> for i386-linux (powerpc as target) for that snapshot?
> Im fairly new to RTEMS and as far as I can see there are no
> old versions
> available on www.rtems.org.
> RTEMS-4.6.2 builds fine but I need/want to stick with the old
> snapshot and
> compiler.
> greetings
> Wolfgang Pedot
