Easy DOSFS question
Etienne Fortin etienne.fortin at sensio.tv
Thu Nov 25 13:45:01 UTC 2004
There should be a filesystem independant way of knowing the free space
on a mount point. Like the get_fs_usage() call in fsusage.c of some
librairy I saw somewhere.
Maybe I should look at that... But anyway, there will have to be some
sort of support from the various file system availables in RTEMS.
I would see something like
#include <rtems/fsinfo.h>
rtems_get_fs_usage(const char* mountpoint);
Maybe adding a function to the fs operations callbacks? Like a fs_stat()
call that would have to be implemented by the file system?
What do you think?
For now, maybe I can create a file of the necessary length (seeking to
the desired size from the file beginning) and if It works, then the
space is available. But it is WAY unoptimized!!! And I don't like
unoptimized and "patchy" things :)
Etienne
