Easy DOSFS question
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Nov 26 01:46:54 UTC 2004
Victor V. Vengerov wrote:
> Etienne Fortin wrote:
>> Maybe I should look at that... But anyway, there will have to be some
>> sort of support from the various file system availables in RTEMS.
>> I would see something like
>> #include <rtems/fsinfo.h>
>> rtems_get_fs_usage(const char* mountpoint);
> Because RTEMS follows to POSIX for file operations, it is reasonable to
> implement statvfs()/fstatvfs(), as they are defined in POSIX (or, at
> least, in man 2 statvfs :-) ).
Not on the Linux box I am using to answer this. :(
>> Maybe adding a function to the fs operations callbacks? Like a fs_stat()
>> call that would have to be implemented by the file system?
> Of course, additional fs callback will be required to support this.
> Victor
