TR : Possible GCC bug on m68k
Etienne Fortin
etienne.fortin at sensio.tv
Tue Nov 2 21:13:11 UTC 2004
Hi Joel,
Packet->number and comp are defined as unsigned char also.
Etienne
-----Message d'origine-----
De : Joel Sherrill <joel at OARcorp.com> [mailto:joel.sherrill at OARcorp.com]
Envoyé : 2 novembre, 2004 16:08
À : Etienne Fortin
Cc : rtems-users at rtems.com
Objet : Re: TR : Possible GCC bug on m68k
Etienne Fortin wrote:
> Hi everyone,
> I know I should put this on the GCC forum, but I want to be sure that
> I'm not mystaken with the behavior I'll describe.
> I have the following code:
> packet->number = (unsigned char)fgetc(sender);
> comp = (unsigned char)fgetc(sender);
> if(packet->number != ~comp)
> return EIO;
> packet->number = 0 and comp = 0xFF.
You do not show types of the various elements in the above fragment so I
can't say. What are packet->number and comp?
I suspect they are 32-bit unsigned integers and with that the behavior
you are describing seems correct. The (unsigned char) is truncating the
return from fgetc() but the "=" is promoting it to the unsigned 32-bit
integer. When you ~comp, you flip the upper 24-bits and there you have
it.
> We would presume that return EIO will NOT be taken. But in fact, it
> is.
> I dissaembled the code and found out that the compiler generated a
> comparison between d0 and d1 register, and that d0=0x00000000 and
> d1=0xFFFFFF00!!! It seems that the code generated by GCC assumes words
> when bytes are compared. The compiler should generate code that make
> sure only the byte of the register is significant in the comparison.
> But it does not.
> Is it a bug? a known behavior? A newbie thing? :)
> And by the way, modifying the above code like this makes it work:
> if(packet->number != (~comp & 0xFF))
> return EIO;
> Etienne Fortin
> Sensio
joel at OARcorp.com On-Line Applications Research
