TR : Possible GCC bug on m68k
Chris Johns
chrisj at rtems.org
Tue Nov 2 23:54:27 UTC 2004
Thomas Doerfler wrote:
> I tried Joels test with a gcc-2.8.1. It also generated code with
> a "long" (32 bit) compare. My idea about that: Wouldn't the "~"
> operator generate an "int" result, forcing the comparision to be
> done with "int" (=32 bit) size? This does not make sense in that
> situation, but this is an issue for the programmer (Etienne) not
> the compiler. Am I totally wrogn with this?
I think you are correct. Here is another example that shows this:
/* m68k-rtems-gcc -g -c -o comp.o comp.c */
int main ()
unsigned char v = 0;
printf ("v = %i (0x%08x)\n", ~v, ~v);
return 0;
The code is:
int main ()
0: 4e56 fffc linkw %fp,#-4
comp.c:6
4: 422e ffff clrb %fp@(-1) <--- correct size
comp.c:7
return 0;
8: 4280 clrl %d0 <--- changed type
a: 102e ffff moveb %fp@(-1),%d0 <--- geting the value
e: 4680 notl %d0
10: 2f00 movel %d0,%sp at -
12: 4280 clrl %d0
14: 102e ffff moveb %fp@(-1),%d0
18: 4680 notl %d0
1a: 2f00 movel %d0,%sp at -
1c: 4879 0000 0000 pea 0 <main>
22: 61ff 0000 0000 bsrl 24 <main+0x24>
28: 4fef 000c lea %sp@(12),%sp
comp.c:8
2c: 4280 clrl %d0
comp.c:9
2e: 4e5e unlk %fp
30: 4e75 rts
I compiled the code on Linux and the result is:
$ ./comp
v = -1 (0xffffffff)
Chris Johns
