Console problem update
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Fri Nov 5 16:23:55 UTC 2004
Etienne,
head is always "ahead" of tail in the ring buffer, so when
head==tail+1, there is exactly one char in the buffer. This is
ok, I would say.
In the last snapshot, you have a bunch of Debug info in the
output buffer, (like "C3D 1.0.0 File Tranfer Test\r\nNeed a
valid FAT12 file system on /dev/nvram0 ") I hope this does not
happen during YMOdem transfer?
Sorry for asking, but do you possibly have a flaw in your
protocol engine design? When there are more characters in the
input than expected, do you consume them properly?
Seems to get a weekend with headaches for you ?
wkr,
Thomas.
> Some more info.
> My rawInBuf is now 1024 bytes. And it gives me the same problem: Head go
> beyond Tail in rawInBuf and rawInBufDropped starts to go up.
> $2 = {forw = 0x0, back = 0x0, refcount = 3, major = 1, minor = 0, isem =
> 436273159, osem = 436273160, cbuf = 0x80d53be4 "ò", ccount = 1, cindex =
> 1, column = 0, read_start_column = 0, termios = {c_iflag = 8450, c_oflag
> = 4294967230, c_cflag = 2237, c_lflag = 32768, c_line = 0 '\0', c_cc =
> "\003\034\177\025\004\n\001\000\021\023\032\000\022\017\027\026\000\000"
> }, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d5407c "", Head = 197,
> Tail = 196, Size = 1024, Semaphore = 436273162},
> rawInBufSemaphoreOptions = 0, rawInBufSemaphoreTimeout = 100,
> rawInBufSemaphoreFirstTimeout = 0, rawInBufDropped = 3, rawOutBuf =
> {theBuf = 0x80d53c70 "\r\n\r\nC3D 1.0.0 File Tranfer Test\r\nNeed a
> valid FAT12 file system on /dev/nvram0 (run fs_create).\r\n\r\nMount
> DOSFS file system on /dev/nvram0 (run fs_create before)\r\nfsmount:
> mounting of \"/dev/nvram0\" to "..., Head = 413, Tail = 413, Size =
> 1024, Semaphore = 436273161}, t_dqlen = 0, rawOutBufState = rob_idle,
> device = {firstOpen = 0x17a8 <console_first_open>, lastClose = 0x1804
> <console_last_close>, pollRead = 0, write = 0x16de
> <console_interrupt_write>, setAttributes = 0x172e
> <console_set_attributes>, stopRemoteTx = 0x1750
> <console_stop_remote_tx>, startRemoteTx = 0x177c
> <console_start_remote_tx>, outputUsesInterrupts = 1}, flow_ctrl = 1,
> lowwater = 512, highwater = 768, rxTaskId = 0, txTaskId = 0, t_line = 0,
> t_sc = 0x0, tty_snd = {sw_pfn = 0, sw_arg = 0x0}, tty_rcv = {sw_pfn = 0,
> sw_arg = 0x0}, tty_rcvwakeup = 0}
> Something to do with the absence of hardware flow control?
> And now no matter what file I send, the problem appears at 12k for a
> 1024 buffers (sooner for a 128 bytes buffer).
> Etienne
> -----Message d'origine-----
> De : Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
> Envoyé : 5 novembre, 2004 09:56
> À : Etienne Fortin; rtems-users at rtems.com
> Objet : RE : RE : RE : Console problem update
> Etienne,
> a baud rate difference of 2% is still tolerable, as
> fas as I know. And you would be well below.
> I just had another look into the data structure
> snapshot you sent this morning (last night...). To
> my suprise, the "flow_ctrl" fiels is non-zero. The
> value 512 means, that the "input is controlled with
> XON/XOFF protocol". Maybe you should try to clear
> the "IXON" and "IXOFF" flags in the c_iflag field of
> termios settings?
> wkr,
> Thomas.
> > Hi Thomas,
> > Yes, the buffer is empty. But, it shows that at least 1161 characters
> > were received. After that, termios thinks there's no more data
> > received or it lost sync or something else.
> > I said before that my baudrate is really 9630 and not 9600. The
> > computer is 9600. Do you think that can be the problem?
> > Etienne
> > Envoyé : 5 novembre, 2004 02:23
> > À : Etienne Fortin
> > Objet : RE : RE : Console problem update
> > Etienne,
> > from the data you sent, the input and output buffer really is
> > "empty", (for rawInBuf and rawOutBuf, "Head" and "Tail" have the
> > same values) but I guess you already saw this.
> > Which BSP are you using? Is it possible your console driver
> > interrupt gets stuck, when there is a receive and transmit
> > interrupt pending at the same time?
> > wkr,
> > Thomas.
> > > Hi Thomas,
> > > Yes a VERY nasty problem... It must have something to do with my
> > > comprehension and the way I implemented the console driver... But, I
> > > was able to make a lot of other things work before (I mean, the
> > > balance of
> > > RTEMS) and I got nasty problem with RTEMS before. But that one is
> > > special. Its so stupid! And I hate to work with transfer protocol.
> You
> > > know you'll be able to make it work, you just don't know when...
> > > Anyway, here's the snapshot of the rtems_termios_tty structure when
> > > the semaphore get stuck.
> > > isem
> > > = 436273159, osem = 436273160, cbuf = 0x80d542a4 "}", ccount = 0,
> > > cindex = 0, column = 0, read_start_column = 0, termios = {c_iflag =
> > > 9474, c_oflag = 4294967230, c_cflag = 2237, c_lflag = 32768, c_line
> > > 0 '\0', c_cc =
> > 0"
> > > }, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d53a98 "", Head =
> > > 1161, Tail = 1161, Size = 2048, Semaphore = 436273162},
> > > rawInBufSemaphoreFirstTimeout = 0, rawInBufDropped = 0, rawOutBuf =
> > > {theBuf = 0x80d543b0 "ransfer...\r\n\r\nC\006C.\r\nrawInBuf.Size =
> > > 2048\r\nPress a key to begin t", Head = 17, Tail = 17, Size = 64,
> > > device
> > > {firstOpen = 0x17a2 <console_first_open>, lastClose = 0x17ea
> > > <console_last_close>, pollRead = 0, write = 0x16dc
> > > <console_interrupt_write>, setAttributes = 0x172c
> > > <console_set_attributes>, stopRemoteTx = 0x174e
> > > <console_stop_remote_tx>, startRemoteTx = 0x1778
> > > 512, lowwater = 64, highwater = 96, rxTaskId = 0, txTaskId = 0,
> > > t_line = 0, t_sc = 0x0, tty_snd = {sw_pfn = 0, sw_arg = 0x0},
> > > tty_rcv = {sw_pfn =
> > 0,
> > > As you can see, I "hardwired" the rawInBuf to be 2048 characters in
> > > size. And surprisingly enough, the Head is at offset 1161. This mean
> > > that I received the first 130 bytes packet (init packet) and some
> part
> > > of the first data packet. But for some reason, termios lost sync and
> > > lost all the next characters, stucking the semaphore and giving me
> > > headaches :)
> > > What do you think???
> > > And by the way, you can't imagine how glad I am to have help from
> > > all
> > > of you on RTEMS forum.
> > > Etienne Fortin
> > > Sensio
> > > Envoyé : 4 novembre, 2004 16:09
> > > Cc : rtems-users at rtems.com
> > > Objet : RE : Console problem update
> > > Etienne,
> > > can you provide a snapshot of the termios data structures when your
> > > console input gets stuck? What values do the buffer pointers have
> > > for the raw input buffer?
> > > What baud rate are you using currently?
> > > What happens, if you write a simple application with two tasks, one
> > > sending a 1K buffer to the console, one receiving it, and putting
> > > the console into loopback mode (with a nice little wire between pin
> > > 2 and 3 of your serial connector)? Does it also hand in that case?
> > > You really seem to have a nasty problem there...
> > > I have been using termios code for machine interfaces back with
> > > RTEMS version 4.0.0, and I never had similar problems...
> > > wkr,
> > > Thomas.
> > > > I don'T know why I tought that even after releasing the sempahore,
> > > > I was still stuck in the idle thread. To the contrary! Forcing the
> > > > release of the semaphore make the task continue to execute code
> > > > and
> > I
> > > > eventually get out of the code with an error (that's ok since the
> > > > semaphore was forced to be released so no valid data is there
> > > > waiting)...
> > > > The question now is why the code is not notified of new
> > > > characters.
> > > > Is
> > > > it possible that the termios code, being designed for "human"
> > > > interraction (at least I presume), can't cope with sustained
> > > > binary data transfer and so I lost data and eventually the
> > > > semaphore is struck waiting for characters that will never come?
> > > > Is it possible?
> > > > Etienne Fortin
> > > > Sensio
> > > > De : Joel Sherrill <joel at OARcorp.com>
> > > > [mailto:joel.sherrill at OARcorp.com]
> > > > Envoyé : 4 novembre, 2004 15:21
> > > > À : Etienne Fortin
> > > > Objet : Re: Console problem update
> > > > Etienne Fortin wrote:
> > > > > Hello all, its me again, the console guy :)
> > > > > Little update for the ones that have an interest, or wish to
> > > > > help
> > > > > me on that matter.
> > > > Is your interrupt an RTEMS ISR or a raw one directly connected to
> > > > hardware?  If you do not go through the RTEMS ISR wrapper, you
> will
> > > > NEVER schedule out of an interrupt.
> > > > Also are you sure you are geting the serial port interrupts?
> > > > > I tricked RTEMS to release the semaphore at each clock tick to
> > > > > make sure the semaphore was the problem. And surprise surprise!
> It
> > > > > still hang in the idle thread!!!!!!!!!
> > > > > Theory: My task/scheduler/... config is fu***d up. Anyone here
> > > > > thinks it can be possible? For what I know of the problem so
> > > > > far, it
> > seems
> > > > > that as soon as the idle thread is entered, no other thread ever
> > > gets
> > > > > executed... Really seems a config problem to me...
> > > > > Idea someone?
> > > > > Etienne Fortin
> > > > > Sensio
> > > > Joel Sherrill, Ph.D.             Director of Research &
> Development
> > > > joel at OARcorp.com                 On-Line Applications Research
> > > > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> > > >     Support Available             (256) 722-9985
> > > IMD Ingenieurbuero fuer Microcomputertechnik
> > > Thomas Doerfler           Herbststrasse 8
> > > D-82178 Puchheim          Germany
> > > email:    Thomas.Doerfler at imd-systems.de
> > > PGP public key available at: http://www.imd- systems.de/pgp_keys.htm
