gen68360 & termios
sebastian ssmoller sebastian.ssmoller at gmx.net
Tue Nov 9 17:05:18 UTC 2004
ok - so why do i get a compiler error when i do this
#define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
rtems_driver_address_table Device_drivers[] = {
    CONSOLE_DRIVER_TABLE_ENTRY,
    TTY1_DRIVER_TABLE_ENTRY,
    TTY2_DRIVER_TABLE_ENTRY,
    CLOCK_DRIVER_TABLE_ENTRY,
    {NULL, NULL, NULL, NULL, NULL, NULL}
to enable ttyS1 ?
errors:
In file included from ../src/sys/kern/loader.c:13:
../src/sys/kern/system.h:80: `TTY1_DRIVER_TABLE_ENTRY' undeclared here
(not in a function)../src/sys/kern/system.h:80: initializer element is
not constant../src/sys/kern/system.h:80: (near initialization for
`Device_drivers[1]')../src/sys/kern/system.h:81:
`TTY2_DRIVER_TABLE_ENTRY' undeclared here (not in a
function)../src/sys/kern/system.h:81: initializer element is not
constant../src/sys/kern/system.h:81: (near initialization for
`Device_drivers[2]')../src/sys/kern/system.h:82: initializer element is
not constant../src/sys/kern/system.h:82: (near initialization for
`Device_drivers[3]')../src/sys/kern/system.h:83: initializer element is
not constant../src/sys/kern/system.h:83: (near initialization for
`Device_drivers[4]') gmake: *** [../obj/m68k/GENERIC/sys/kern/loader.o]
Error 1
i couldnt find TTY1_DRIVER_TABLE_ENTRY in gen68360 bsp anyway - is this
handled differently there ?
i had a look at console/console.c but it doesnt gave me a hint on how to
deal with ttyS[12] as known from pc386 bsp.
any ideas while a simple tcgetattr & tcsetattr (without changing
anything ) causes my stdout to be broken ?
much thx for ur help,
seb
> Sebastian,
> gen68360 BSP has full termios support. Have a look into
> "gen68360/console/console.c". The primary device is called
> "/dev/console".
> wkr,
> Thomas.
> > hi,
> > is it correct that this bsp has no tty driver (e.g. like pc386) or
> > did i
> > miss something (havnt found any tty_drv.h or s.th. like that)
> > is there any other possibility to access smc2/com2 ?
> > (using open() without CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
> > results in errors)
> > does this bsp have full termios support?
> > anytime i try to change some settings i get bogus output
> > code sample:
> > tcgetattr(0, &std_in);
> > std_in.c_cc[VMIN] = 1;
> > std_in.c_cc[VTIME] = 0;
> > std_in.c_lflag &=
> >     ~(ICANON | ECHO | ECHONL | ECHOK | ECHOE | ECHOPRT | ECHOCTL);
> > tcsetattr(0, TCSANOW, &std_in);
> > even if i does not change anything at all (just call tcgetattr and
> > tcsetattr) this prob happens :(
> > any ideas ?
> > THX
> > regards,
> > seb
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_keys.htm
"Perfection is achieved, not when there is nothing left to add,
but when there is nothing left to take away."
--- Antoine de St. Exupery, Wind, Sand, and Stars, 1939
