Setting up Telnetd?
Ian Caddy ianc at microsol.iinet.net.au
Wed Nov 10 01:50:25 UTC 2004
Hi Alan,
We use telnet and shell with RTEMS4.5.0 on a Coldfire 5307 device, so I
am not sure if this is appropriate to you if you are using the latest RTEMS.
When we configure our device table, we also setup an entry for the size
of the table:
#define NUMBER_DEVICE_DRIVERS ( (sizeof(Device_drivers) /
sizeof(rtems_driver_address_table) ) - 1 )
You didn't show it but I assume you have provided this entry (and that
it is still required for later RTEMS versions).
It sounds like your pty interface is being initialised otherwise the
telnetd will not call the shell_init with a valid device number.
What was the errno returned at the end of the error message, as that
will indicate the reason why you couldn't open stdin?
Do you have a debugger that you can step through the code, starting from
shell_shell (shell.c) and following through the fopen call?
I hope this has provided some help.
regards,
Ian Caddy
Alan Cudmore wrote:
> I'm trying to set up the telnetd on a coldfire target. It has a working
> network driver and FTPD.
> I created a device table entry for the PTY device:
> #define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
> rtems_driver_address_table Device_drivers[] = {
> CONSOLE_DRIVER_TABLE_ENTRY,
> CLOCK_DRIVER_TABLE_ENTRY,
> PTY_DRIVER_TABLE_ENTRY,
> I call rtems_initialize_telnetd() in my init program.
> When I bring the board up and telnet to it, I get a printf on the
> console that tells me that the shell cannot open stdin./dev/pty0
> Is there anything else I left out?
> Thanks,
> Alan
