rtems_message_queue_receive
Steve Holle
sholle at link-comm.com
Thu Nov 11 19:01:50 UTC 2004
Follow up :
Is it possible that I am hogging the Message Manager by sending these
messages? I'm sending 256 bytes of data every 16mS.
At 09:52 AM 11/11/2004, Steve Holle wrote:
>Good catch about the interrupts. I did find one interrupt that was a,
>shall we say, non-conformist, and fixed it but I'm still having
>problems. Let me explain my problem with a little more detail.
>Our system has two main threads, one running our fltk based GUI and the
>other running everything else. We also have a number of threads running
>network functions, such as telnet, ftp, and a webserver. All this has
>been running fine up to this point.
>I'm trying to add a data stream that comes from one of the DSP cards in
>our system, streams data to a remote system over the network and receives
>data back from the network for output to the DSP. The data transfer is
>initiated by an interrupt (conforming) generated by the DSP card which
>passes the DSP-to-net data via a blocking rtems-queue in another
>thread. In the same interrupt, we are passing data from another
>rtems-queue to the DSP. The last queue is filled in a blocking RX queue.
>I've tried to fashion my code based on the telnet server that we have
>running, a very simple one connection telnet app.
>If I comment out the code in the interrupt that sends the data to the
>queue that is read in the blocked thread waiting to transmit over the
>network, everything works fine. As soon as I try to enable the queue
>write, the GUI locks up. What I mean by that is that it becomes
>unresponsive and actually does not complete a screen refresh that is in
>progress.
>I've read the GUI thread status from the streaming server with an assert
>if it is ever inactive and it always reads back active. My other main
>thread seems to run fine. I can communicate with it via a serial terminal
>and the response is snappy.
>When we run the BMD, before the call in the interrupt we are able to break
>in the main while loop of the GUI. After the call, the program will no
>longer break inside the GUI main while loop.
>I'm not sure how to proceed from here. Any ideas?
>At 06:22 PM 11/10/2004, Ian Caddy wrote:
>>Hi Steve,
>>rtems_message_queue_send is allowed from conforming interrupts. In other
>>words interrupts that use rtems_interrupt_catch to establish them.
>>It is also important to note that any lower priority interrupt than the
>>one where you are calling RTEMS functions must also be conforming interrupts.
>>When you say hangs, do you mean the processor stops (I think from memory
>>you are using a Coldfire?) you should be able to put a BDM onto your
>>system with gdb and run it normally until it stops. Then get control
>>back in gdb and it should indicate where the more than likely bus error
>>is, to see if you can narrow down your problem.
>>I hope this helps,
>>Ian Caddy
>>Steve Holle wrote:
>>>I have what is probably a basic question about
>>>rtems_message_queue_receive. If I am using rtems_message_queue_receive
>>>with the RTEMS_WAIT attribute set in a server thread, can I fill the
>>>thread using rtems_message_queue_send in an interrupt? It seems almost
>>>as if the rtems_message_queue_send is being blocked by the
>>>rtems_message_queue_receive and my code hangs in the interrupt.
>>>On the other hand, I may be doing something really stupid ;-}
>>>Steve Holle
>>>Link Communications, Inc.
>>>1035 Cerise Rd.
>>>Billings, MT 59101
>>Steve Holle
>>1035 Cerise Rd.
>>Billings, MT 59101
Steve Holle
1035 Cerise Rd.
Billings, MT 59101
